URGENTLY WANTED - Corpet Louvet small motion screws
Buy now for 0 USD
I am currently assembling an LGB Corpet Lovet 0-6-0 chassis that I have been given as a "bag of parts". Unfortunately, I cannot assemble the motion as the person who originally took the thing apart has not saved the small shouldered set pins that hold the valve gear / motion together!
Does someone have a dozen or so small motion pins that they would be willing to sell me as I would dearly love to return this "expensive jigsaw" back to one cohesive lump? Model land do sell them, but you have to buy a complete set of valve gear in order to get them!
Note I do have all six main bearing crank pins (ones that screw directly into wheels). The ones that I need are the very small ones that form the hinge points of all remaining valve gear.
Also still looking for a wiring board, loco weight and complete rear cab sheet (both parts) if anybody has any of these they do not want?
Thanks in advance
Dave
Thanks in advance
Dave
Have you looked at this?
These aftermarket linkage screws are advertised for the later Stainz. (Among others.) Not sure if they would fit the Corpet, but if you have a Stainz knocking around, it might be worth checking to see if they are the same.
Regards,
Paul.
Regards,
Paul.
Ah, thanks for the heads-up Paul - I hadn't seen these. I'll check them out!
Dave
Gestängeverbindungsschraube 10 Stück ML-Train 88101015
Out of interest, as my German is as good as a punctured football, and the translation tool doesn't seem to understand it either, does that one word actually translate as small screw for valve gear? Being a total dunce with actually using languages, I'm strangely interested in them.
Linkage screw 10 pieces ML-Train 88101015​
NB; Their site has a handy German to English translation facility, or you can set 'Giggle' to do it automatically.
Luckily for me, I'm bilingual. Unfortunately the other language is gibberish. ;)
Thank you gentlemen you are all stars! - I'm afraid that my bi-lingualism only runs to The Queens and Black Country English - with a smattering of "Old Irish" when things don't go as planned!
I will get an order to you ASAP Mark
Dave
Hi Dave, Sorry about that, Should be fixed now.
Mark
Hi Mark,
Thanks for letting me know. I can now add it to the basket OK. However, I am finding the same issue with some other products. In particular, I also tried adding a pack of Dome Lens to the order, however received the same error. Do you happen to know what is causing this? Just wanted to check as I had a couple of items I was planning to add to make it a combined order.
Thanks,
Dave
Dave, Should all be sorted now. Thanks.
