Hi all,
As one who works with paint all the time, one thing to remember with the undercoat business is that the undercoat can affect the exact colour of the top coat.Not used Halfords paint (except on a car!) so I don't know if this is the case but its worth testing (some paints like some precision ones are designed to go over certain colour undercoats!).
With all types of painting I would recommend always using an undercoat and always use the undercoat designed for the top coat if at all possible. I tend to use gamesworkshop acrylic black or white spray cans as I use various acrylic paints for topcoats etc. However I have used plasticote grey undercoat for this too!
Plus as a general tip be careful to avoid reactions between types of paint they can really bugger up a job! I had one I hadn't encountered before with plasticote on a roof the other day when it appears I left the undercoat too long before applying the top coat (a new one on me but its the only explanation I could arrive at for the reaction).
One thing with wooden sides is how smooth do you want the paint finish? As mentioned above to get a really smooth finish on wood a sanding sealer (or substitute as suggested by Tim above) is essential really, (using just an undercoat paint for this would be difficult I think) I tend to like my coaches really smooth sided so I apply lots of layers of sealer, sanding down each one well (if the coach has beading etc be careful not to ruin the definition by taking off the edges and rounding them off!). The coaches below are wooden, almost totally smooth finished and were done this way, then painted with a plasticote grey undercoat and top coat. I normally shy away from this type of paint but have found that this combination work well and probably help to fill the last few blemishes.
With my "work in progress" brakevan, also seen below, the finish is slightly less smooth as I felt befitted a more work-a-day vehicle so I just didn't sand and seal so much! Sorry for the rubbish photo but you can see a slightly rougher finish on the door etc where the grain shows through..... I will be weathering this vehicle more too....
ATB
Steph'
