beavercreek
In another thread I had solicited advice as to how to have DCC or DC operation on a DC shuttle with adding the option of DCC reverse loop at either end scenario.
That little 'change' has progressed nicely but I have what some folk would see as a very common sense query, but I do need confirmation that I have the right idea!
When my shuttle line was just DC, I used resistors in the track to slow down the approach and leaving of the train into/from the station.
(I also used this system on the mainline, to slow trains through a station).
Now that the DC shuttle now has the option of being switched over to a double reverse loop when in DCC mode and back to shuttle when in DC..my query is ...
At the moment I have a switch which cuts in or out a bypass for the 'end' diode for the 'DC shuttle' when I want to operate in DC mode and run some analogue locos (that do not like DCC waveform..I am considering implementing the DC reverse loop option but not yet)).
This diode switch/bypass could also be configured to cut, in or out, track resistors so a DC shuttle train slows like before.
So my question is.....
BUT if the switch was accidentally left on when in DCC autoreverse loop mode, would the resistors work exactly the same way with the DCC AC power and cause a slow down, though not in the right place of course?
(Whereas the DC shuttle only slows into and out of the station, the DCC reverse loop running will go through the station).
My brain says "Of course idiot!".... but here is some nagging feeling that I am missing something....................most probably
