W&L Coach Chains
I have a few questions on the W&L Pickering coach chains (and other stock come to that), which hang by the side of the coupling arm. If anybody can help.
1). Just how did they work on the prototype? The model chains are not long enough to inter-connect without some form of bridging extension.
2). Do modelers use them as in prototype practice or is that just too fiddly.
I would like to assume that if connected the chains would be lifted clear of the coupling arm so when run with a Guards Van all would be OK.
My main line is made up of R3 but due to space restrictions I have had to use some R2 transitions.
When the chains hang free on odd occasions they have fouled the coupling arm.
I know the recommended Radii is R3 but many of you experiment & achieve.
I also have a few R1/R2 transitions on sidings so would also like to be able to park up off the main line without handling.
I have hooked the chain up to the platform this seems to work, but looks awful.
I know when the bronze & white were first delivered they had no chains
(fitted soon after arrival) but I am reluctant to remove them, I just like em.
