Water crane
ge_rik
Hi folks
After just over ten years, locos on my railway have at last been given the means to quench their thirsts - a water tower (from a Model Town kit) and a water crane have been added to the main station.
Having looked around for suitable off the shelf models or kits, I felt I could cobble something together myself ....
Ingredients:
  • main column = 5mm wooden dowel
  • collars on the column = plastic tubing and barrel from a cheap biro
  • base of column = tap washer
  • valve housing = 10mm wooden bead
  • valve = casting from Cambrian Models
  • cap on column = end of plastic test tube
  • joints on column = metal washers
  • counterweight = end of plastic party 'blower'
  • arm = 4mm wooden dowel covered in 5mm plastic tube
  • support for arm = brass rod
  • hose - heatshrink tubing
OK - it's not perfectly to scale, but I think it gives the essence of the real thing ......
It needs to be weathered and installed at the end of the platform, but I think it does the job!
More info about this and other developments on my blog - https://riksrailway.blogspot.co.uk/2017/06/progress-report-68.html
Rik
Rik
Looks good but I'm not sure about the wooden base, also most of the european jobbies have a lamp on the top end of the arm (in Luxembourg and Germany red and white). :call:
Hi
The base is temporary - just to hold it upright when being sprayed. My railway is UK-based so I felt I didn't need the lamp.
Rik
