maxi-model
While I could just solder these JST pins (see image below) up to their wires I wonder if anybody could tell me which type/make of crimper I would need to buy to assemble these as intended dry jointed ? I suppose I could just ask one of the suppliers, e.g. Fosworks, that use them but I thought I might get a wider range of responces here. I have seen some tutorials on YouTube but they don't specify the actual tool used. I have worked out how to extract the pins a long time ago but not how to properly assemble them, from new, in the first place.
Sub question - It dawned on me while searching around the WWW that the JST pins are of a standardised design, if not size. Could I use the same pins to "refresh" those used in multi pin connectors used in Bachmann locos like 3 truck Shay and others ? That 8 pin connector between loco and 3rd truck/tender. Wires break off after time (I did not get the message of dropping some silicon in) and my soldered rejoining, while perfectly servicable, is not ideal to my tidy mind. If I can what would be the way of identifying size/type of pin (only) to order the correct replacement ?
