What is a good material to simulate cable for G scale
Try some thin Bowden cable, similar to bike brake cable, ( obvious a lot smaller though). We use short lengths to seal meters
Stripped and slightly twisted multi-strand wire? You could even run a little solder along (with plenty of flux) if you need to ensure it doesn't untwist and split. Depends what thickness of cable you need I guess?
I would be tempted to use a good thick sewing thread brown colour. I have a good wooden reel ofvthe stuff that I use for buttons and they never come off again when I use it.
Braided fishing line.
Amazon: Amazon.com : 100 Meter 0.35mm Fishing stee Wire Nylon Coated 1x7 Stainless Steel Leader Wire super soft Fishing wire lines 15 Pound Test : Sports & Outdoors
Electric guitar or bass strings? I try and save some of my lad's cast-offs, various gauges.
If you want to maintain the appearance of the cable being under tension, try shirring elastic thread. I use it to retain loads either on its own often doubled up, or to tension some jewellers chain. It is readily available in a number of thicknesses and colours and most inexpensive.
My "winch" or winding drum for a project never finished!
or a zip wire?
I spent 21 years actively involved with cables at the Glen Tramway - fitting, shortening, etc.
