While not 'wireless charging' last time we went to the model village in Anglesea, the trains there had charging terminals, which looked like check rails, which charged the loco each time it stopped in the station. It seemed to be working OK, and as it was obviously a wiping contact under the loco, would be self cleaning, without the ugly 'skates' that stick out of some LGBs locos. I assume that they had a timer in the loco to restart after a set time in the station, as it only seemed to stop for 30 seconds or so in the station. I'm sure this could be done with the running rails and the loco pick-ups, but probably less reliably due to the general dirt that seems to form on the rails and wheels in the garden. What do others think.Yes...
Advantages:
Less handling of models.
You don't misplace your charger.
Disadvantages:
Fixed charging point. - You can't take it with you.
Not particularly efficient. - Low current transfer. It will take many hours, to charge the batteries we use.
Not a good idea to 'just leave things running'. - You really want to be in the vicinity, keeping a weather-eye, on things.
An extra layer of complexity, for the user. - This is OK for those with the technical knowledge, especially if using Lithium-based battery technology.
Your battery toothbrush, is used for two minutes, and has all day to charge. - Most of these small units transfer 100mA or so..
Do the maths, for charging a 5000mAh battery.
Yes, on reflection that is true, you would need effectively a charger minus the PSU in each loco to take care of various size/No. of cells/etc.. I assume that there is something like that in wireless charged devices, phones etc. but wether it is worth it for the convenience of wireless charging a loco for Chris, along with the extra time it would take, I suspect not.It also means having all the intelligence to manage the batteries and charging, in each loco..
You can't rely on the integrity of the contact between loco and track, to manage this off the loco.
You are also reliant on the BMS board on the battery pack, with no easy way to check the individual cells.
