z21 XL: Dropping the voltage
Andrew_au
I have a z21 XL that puts out 20v. I also have a couple of HO scale locos, that I believe want about 15V. I'm in the process of getting myself a DCC-EX system, but in the meantime is there an easy way to drop the effective output voltage down to 15V so I can use the XL with the HO locos?
I theory I could add a resistor or a pair of chains of diodes, but I'm concerned about the heat dissipation and whether the extra components would negatively affect the DCC waveform.
I'm pretty sure there are software settings for the z21 that control the nominal output voltage. I'm sure someone will be along soon with more detail on that.
Looking at a XLS manual there are possibly 3 cv’s that will be candidates.
CV2 starting voltage which is default 2 which is 2 parts of the track voltage divided by 255.
CV5 top speed default 200 which is calculated similar to the above.
CV6 mid speed default 50 again a similar calculation to above.
In the CV60 series are ‘load control’ functions that I am not familiar with never having messed with them, but a concern may be that they push higher voltage to the motor should there be a heavy load?
There are also CvV adjustments that control the voltage value to lights if your loco is fitted with lights that may also need adjustment.
I would be happier if someone could confirm my assumptions as shown above, would not like to lead Andrew on a headlong path to trash his loco!
Regular z21 has customisable voltage. z21 XL has fixed voltage.
Jon, are you suggesting that the average HO decoder is happy with a 20V supply as long as I turn down the voltage to the motor?
The Z21XL manual notes....
Maximum input voltage for the Z21 Digital System is 24 V. The maximum track voltage is always 1 V below the input voltage.
So perhaps using a lower input voltage might be the way!
I was looking for confirmation of that, but I am not sure it has been given. I thought your decoder was a G scale one?
The NMRA S-9.1 Electrical Standards for Digital Command Control. (recommended practice) value for H0 scale is a maximum of 15V, with many DCC supplies recommending 13.8V
Individual devoder suppliers may have different ratings but it seems to me that 20V on the track would quite risky.
