3D printed clip-on buffer stop
ebay mike
6 Dec 2011
4,082
717
Norfolk - edge of nowhere.
I bought these on eBay a few days ago. You get five for the princely sum of £12.49 including P&P, but they are also available separately. They are sold as gauge 1 but as I was in need of some less costly items for my storage tracks radiating from my turntable I thought it worth a punt and anticipated a little conversion work would be necessary. On arrival I noticed the slot for the railhead was bigger than what I had expected (code 250?) and with a quick clean up of some minimal flash I found LGB rail fitted nicely. The spacing of the 'feet' does mean a small piece needs to be removed from the track webbing so two sleepers are moved closer together by a few millimetres, but I can live with that. It is also necessary for the rail to be slid out of the sleepers so that the framework can be inserted as it will not slide past the chairs. It may be possible to push-fit from the top. but I wouldn't want to risk it, not knowing the limitations of the product's flexibility. The pegs on the back of the crossbeam look a little fragile and I will consider replacing with something stronger. I have no idea what (if any) prototype they portray, but I consider them more than suitable for my needs. Detail is quite good and they line up reasonably well with buffers on rolling stock. I'm not sure how they will stand up to outside use though- we will have to see. Link and my photos below.
Gizzy
36,220
2,298
63
Cambridgeshire
They work quite well Mike.
I used the Peco ones on Hardyard, as they have a very small footprint, but I might have used those if they had been available at the time....
Riograndad
6 Jul 2013
2,161
639
69
Northampton UK
If they do the job of stopping anything coming off the end they will do nicely.;)
GAP
14 Jun 2011
4,067
948
Australia
A coat of grey exterior spray paint will protect them, after saying that I have had some test pieces lying out on my layout in the Australian sun for 2 summers now and they show no sign of deterioration. The filament used was PLA+.
3,553
curtis curtis You might find these acceptable?
You do have to fettle a mounting for your lamps, though.
