Really very good. Another interesting project.
Regarding the motor and gearbox assembly. Where do you get these from? I am fairly new to modeling and I am interested to find a source of reliable motor/gearbox assemblies.
Thanks.
Tim
He is making his own.. How reliable? We will hopefully get a report back!
It is one of those things that people are scared of (like 'quartering').. Being methodical, having played with Meccano (or equivalent) helps. Mainly everything needs to be square, parallel or at right-angles, and you need to mesh the gears with just a little play. - Should not be tight..
A number of suppliers do a selection of gearboxes (or frames) and motors.. Here in the UK, you can get 'Como Drill' motors and gearkits from the likes of Maplins'. - A good start of something to play with.
IP Enigneering does a 'wooden' laser-cut motor-mount / gearbox. Check the websites..
HTH
