Technocrat
Mostly Retired?
Thankscreality
You can download Ender-3 S1 's product manual & firmware and slicing software on here.www.creality.com
Thankscreality
Those look like slicer errors. Check for number of top layers - should be 3. Also check retraction settings and maybe increase a little.Success! Sort of. At least it printed.
My foolishness of course. My z offset was set to 3.32, not -3.32 as required.....
Now to fiddle withe the settings to get the horizontal surfaces to work.
Thanks for all the input guys, I have a lot to think about.
8GB micro SD CardYou need the original files on the card
Otherwise the printer will -can forget..you also need a small ,( thing it's 8mg ) card ,not a bigger micro sd card, as this too can bugger it up..
Nice!My experience with Creality's slicer was to download the latest version and use that, it is based on Cura so personally I saw no advantage in changing.
Not being very experienced with 3D printing I stayed with what came with the printer although I did upgrade the firmware which gave me a lot more functionality.creality
You can download Ender-3 S1 Pro 's product manual & firmware and slicing software on here.www.creality.com
How to Update the Firmware on an Ender 3 - Simple Guide
Learn how to update the firmware on your Ender 3 to unlock powerful features. This step-by-step guide has all the details you need.3dprinterly.com
After fitting the new springs, the firmware and slicer updates I went from this;
To This
Any chance of getting the 3D solid file?My experience with Creality's slicer was to download the latest version and use that, it is based on Cura so personally I saw no advantage in changing.
To This
I'm assuming you are after the bogie files, I got them from here, I'm using the bolster without the hook tongue.Any chance of getting the 3D solid file?
Thank you so muchI'm assuming you are after the bogie files, I got them from here, I'm using the bolster without the hook tongue.
Bogies for LGB cars
Bogies for LGB-cars. Will fit for instance the heavy load car I've created but also other cars. I've added one version with hook holder (standard LGB hook will fit) and one version without holder. I've also added complete files for reference or so you can download and use in your own projects...cults3d.com
I also printed these but as I was using body mounted knuckle couplers I used the ones above.
ou so much
These are the couplers I am using, they work very well and do not uncouple even when they go over a small raised section of track that needs levelling.
Knuckle coupler 1/32 - Scale I - Openrailway by raby
Since a long time I had in mind to design a 1/32 scale knuckle coupler to replace the oversized LGB coupler on my US rail cars. After a few inconclusive tries I finally found an easy to print and functional design.The automatic coupling is working as expected and it doesn't unhook even in tight...www.thingiverse.com
I found the bogies here, Yeggi is my favourite site for stl files
"lgb bogie" 3D Models to Print - yeggi
1951 "lgb bogie" printable 3D Models. Every Day new 3D Models from all over the World. Click to find the best Results for lgb bogie Models for your 3D Printer.www.yeggi.com
Welcome Yeggi is the google of stl files I usually get files from Thingaverse and Cults on itThank you so much
