Very nice. awesome use of odds and ends. Love the pipes looks very realistic.Second lot
The planking on the flat car is made from paddle pop/coffee stirrer sticks glued on and stained with acrylic artist paints diluted with methylated spirit/de-natured alcohol.
In the first pic you can make out the pieces of flat steel that is used to prevent warping of the MDF deck and adds weight, all my wagons are on the same chassis design.
Bogies are made from styrene and plastic cornice molding.
The pipes are 25mm PVC electrical conduit with the flanges cut from an old plastic sign, the rests are just pieces of timber with grooves (made with a round file) to stop the pipes from rolling sideways.
The chains on both are from the cheap/DIY jewelry section of a $2 shop, in the gondola they are attached by hook and loop dressmaking accessories and rivets that I bought from a bloke in Sri Lanka (goes by the name of Pasidump on ebay) who make G Scale kits of short flat cars.
My next project is to attempt to make a diesel loco based loosely on an RS-3 using a Little Critter as the short hood and cabin and trying to make a long hood and extend the deck.
I have a motor block that I can use and I plan to clone the side bars.
I would like an RS-3 but to get one to Aust costs more in postage than what I could buy one, last time I looked $450 US for the loco and $500 for postage and handling, so this is my solution.
Might take a while but who knows biggest problem will be shaping the long hood, the rest should be easy (famous last words??).
I do like the old chassis on topThe last 2 of my "therapy wagons" are now complete, they were originally started to give me something to do while recovering from hip replacement surgery but took a little longer to finish than I planned there are 6 wagons in all to go behind my Bachmann "Connie".
First lot are a gondola with scrap vehicles going to recycle yard, I found the vehicles in a market stall amongst some old toys total cost 50c, the dents are the result of the use of a blow torch and some shaping.
I varnished the wood instead of painting it because SWMBO said it would be a shame to cover it up, the "bolts" are brass dressmaking pins.
he doesn't see them.THAT is what our modelling is all about...wait until our Paraguayan pal see them!!
and if he would, he would be extremly jealous. because the only project smaller than 1:1, that he did in this year, was a model of a new firestation. (in vain. the project was not aproved)
how many times a man has to retire, before he gets time for modeling?
till now, i got the impression, that the sole difference between work and retirement is, that one may choose freely, what work to do first.
(for married men this may be only partially true)
Looks like a good plan to me.
Quite like that..
Think I might have investigated if I could have reduced the height of the cab/engine compartment. - To make a step in the roofline..
Just think it might have added a little. YMMV, and rule 8, of course.
Funny you say that because I raised the cab height to try and get the roofs level, the coach roof extended over the cab roof in the initial design and was bent to blend it in.
The design company may get a design deviation request which will be sent to the Dremel workshop for the change. Standby to standby
Do not recognize the acronym YMMV.
