Now is the reveal time. Having waited a day or so for coat 2 of the Red Oxide to dry off it was time for the Black for the Ironwork. 1st bit of masking removed and looking ok.
![C6193D3D-B3F6-4D2B-BBE6-752411378C2C.jpeg C6193D3D-B3F6-4D2B-BBE6-752411378C2C.jpeg](https://cdn.gscalecentral.net/2020/07/thumb/290316_C6193D3D-B3F6-4D2B-BBE6-752411378C2C.jpeg)
A little diversion to Numbers and the new Wagon Card that have been produced. I have numbered the Van in the correct sequence for Bogie Vans in the Harz even though this one is somewhat fictional. Bits of pipe for Water Cranes littering the workbench started while waiting for paint to dry. Well that is such a boring process. It is always so tempting to get that masking off but it does need a good 24 hours to harden off no matter how dry it may feel to the finger.
![6CFF6AEB-D414-464A-AA19-DB75183A2542.jpeg 6CFF6AEB-D414-464A-AA19-DB75183A2542.jpeg](https://cdn.gscalecentral.net/2020/07/thumb/290317_6CFF6AEB-D414-464A-AA19-DB75183A2542.jpeg)
Now the bodywork is revealed, note the bit of Masking showing that it has done its job with the Oxide lines that will have ultimately sealed the edges. If that second coat had not worked you would be looking at black lines.
![19AC6136-5D84-4220-A9BC-D640E97357C5.jpeg 19AC6136-5D84-4220-A9BC-D640E97357C5.jpeg](https://cdn.gscalecentral.net/2020/07/thumb/290318_19AC6136-5D84-4220-A9BC-D640E97357C5.jpeg)
Not a 100% success, just a tiny bit of bleed top right at the end. But that is pretty well all thankfully, that will be resolved by spraying a small quantity of the Oxide into a Spray Can Top so that I can apply a little to loose that black with a brush.
![7155193D-63E1-4660-8A80-85CE50952A4A.jpeg 7155193D-63E1-4660-8A80-85CE50952A4A.jpeg](https://cdn.gscalecentral.net/2020/07/thumb/290319_7155193D-63E1-4660-8A80-85CE50952A4A.jpeg)
The doors now all revealed.
![5FC72D71-BF9A-42C1-AA29-7197CCC41B0C.jpeg 5FC72D71-BF9A-42C1-AA29-7197CCC41B0C.jpeg](https://cdn.gscalecentral.net/2020/07/thumb/290320_5FC72D71-BF9A-42C1-AA29-7197CCC41B0C.jpeg)
On test fitting the doors I realised there was some view of the inside so the edges have been hand splashed black. Could have saved myself some masking there!
![11205FCF-3F07-454F-84D9-9ED579E6B3F1.jpeg 11205FCF-3F07-454F-84D9-9ED579E6B3F1.jpeg](https://cdn.gscalecentral.net/2020/07/thumb/290321_11205FCF-3F07-454F-84D9-9ED579E6B3F1.jpeg)
Fitting the doors, the varying slides have been hafixed in place hence the weights from a Trainline Mallet being used to keep things in place, these have proved very useful since being removed from the loco to make space for the Battery Conversion. The van body has been held in place on the donor chassis with LGB crews drilled through into cross pieces of Foamboard within the van body
![DDC61477-128D-4863-A636-AB724B5D47D8.jpeg DDC61477-128D-4863-A636-AB724B5D47D8.jpeg](https://cdn.gscalecentral.net/2020/07/thumb/290322_DDC61477-128D-4863-A636-AB724B5D47D8.jpeg)
Next job to sort out the roof.
