I believe someone tested a RH boiler to the point to failure (hyd test, not under steam) and it was in excess of 190lbs of pressure if not over 200.(been awhile since I read that article).  SO there is a huge safety factor in these.  I know plenty of engines in the USA that have that up rated safety in them and there have been no issues that I am aware of. The weeping safety, starting as low as 20-30psi, is my one complaint with the RH line.  A safety that blows off at the designed 40psi, then snaps closed smartly is what is needed and not hard to make.  That would be my one suggestion to Rodger, to redesign the safety valve they use blow off at 40psi, or whatever pressure they want, then have it snap closed as quickly as it opened  Not weep steam so you have a trail over the train the whole time you run.  That is wasteful of steam.  If the valve operated better, there would be no market for aftermarket ones.   Otherwise, I absolutly love the brand and models and plan to order one(hopefully) next summer.      Mike
