tac foley
Well, Folks, I guess it had to happen sooner or later, the safety valve on my 3C-Shay, the very first example sold in UK, direct from the Accucraft stand to Steve Warrington and then me, has gone to the safety valve heaven. Checking the loco over for its annual documented test last Friday, after a three-month hiatus, and the SV failed to lift at the usual 65psi, and climbed to the stop, whereupon I turned it off and let it cool down.
Some suggest that the dome cover simply lifts, while others that it unscrews. Neither would seem to the case - without using what I consider to be undue force, that is. Given the rarity of these early versions, and its sentimental value to me, I'm loathe to apply too much by way of brute force.
Right now it's having another dose of penetrating oil in the only area where there just MIGHT be a thread...
The usual suspects have been contacted for advice - they know who they are, and thanks, Guys.
However, your suggestments would also be valued.
TIA
TIA
