Rhinochugger
Retired Oik
Ah, just check the Coffee Room chat - I managed to keep the spring on the wallet firmly snapped shutOK, let's see what you bought then![]()
I am going to use that analogy next week at week, I have no doubt the opportunity will present itselfNope. that was the very first thing I did and looked for. It's as blank as an idiot's smile.![]()
Lovely expressionIt's as blank as an idiot's smile.![]()
GotchaThose of us who shoot older-style rifles and muskets have another saying, which won't have much resonance over here in UK, but will certainly ring bells over in the USA.
'As clean as a militiamans target.'
I forgot. It's threaded. Remove steam pipe, as suggested, lift dome and rotate anti clockwise so it's threaded base engages with those in the boiler saddle mount. Process of elimination (and why was the paint scuffed on those little bolts holding on the steam pipe on mine ?) May you now have many more years of enjoyment from your beloved Shay. MaxNope. that was the very first thing I did and looked for. It's as blank as an idiot's smile.![]()
With the dome having an internal thread, you could be correct.With metal that thick, and the amount of "engagement" being able to heat the saddle part without heating the dome part would be difficult.
Note, you do not want to heat the dome, quite the opposite, an ice cube on the dome is what you want, you want the dome cooler, and the saddle hotter..
I wish..........................................sigh....................................................................................No special treatment required, heat or otherwise. Just make sure you hold the dome up when you turn so its threads engage with those on the saddle. Max
Looking at Max's photo, I think it isSilly question, but is it definitely a R/H thread.
So, the strap wrench slips?
Any way to add pieces of leather? That suggestion would work well I think.
