funandtrains
Not wishing to decry RCS I know that they
are good kit and I personally would have no problem in sourcing from Oz. however for Callum on his first install, if he does one a UK supplier would be a better bet.
I have an Accucraft Caradoc for sale which is in lovely condition and has been upgraded with Summerlands Chuffer, DJB whistle and drain cocks and a Clive Marker radio control system (this is a small knob type) which I'm asking £800 for.
Appologies for that was getting confused with the other supplier from Oz that does similar kit. I only have experience with Peter Spoerer kit and that is what I was trying to say, not trying to indicate what is best. Incidently I have no connection with Peter Spoerer, just a satisfied customer.RC Trains are a UK based supplier, what are you on about????
Must say that do look smart. Any more info on the loco?I have an Accucraft Caradoc for sale which is in lovely condition and has been upgraded with Summerlands Chuffer, DJB whistle and drain cocks and a Clive Marker radio control system (this is a small knob type) which I'm asking £800 for.
Hi all.
After the success with my first live steamer (a Regner Konrad), I've been thinking about getting a second engine. One that has really caught my eye, and is within my price range is the Accucraft Ragleth.
It also meets my critieria for going around R1 curves, which my layout is consists off.
Another slightly cheaper option is a Roundhouse Basic line model, so would like to know which would be best.
First of all, is it best to pay that bit extra for R/C?
I don't have any issue with manual models, but I've heard the sometimes need a bit more omph to get them around bends (especially tight ones). This is where R\C would come in a bout more handy than manual I guess? Giving it a bit more reg on the bend then less on straights.
Second, cleaning.
I know live steams can get a bit dirty, so would like to know what us recommend to keeping the paint work and other things in top condition.
Any help would be greatful. As you all know a live steamer is not a cheap purchase, a would like to get it right.
Many thanks callum
Stephen. That shouldn't be happening. I suggest that you check the back to back measurements of the wheels.Does anyone know whether or not the Accucraft Ragleth will run without problems on LGB track and point work? I have two Roundhouse locomotives that will not run over standard LGB points, so I have had to shim the catch rails using thin brass strips. It does work well and the locomotives run through the points in all directions without derailing.
I've just checked the gauge of my Roundhouse locomotives against my LGB locomotives and they are identical. The big difference is in the flange depth of the LGB wheels, as it is almost twice that of the Roundhouse wheels. I'm sure that if I could put LGB wheels on my Roundhouse locomotives then the problem would not exist.From what you say above, I think I would widen the gauge a little??
I have never had a moments problem with running Roundhose Locomotives through LGB R1 Points, I have had 4 of them in my time plus visiting ones as well. Cannot understand what is going on here.I've just checked the gauge of my Roundhouse locomotives against my LGB locomotives and they are identical. The big difference is in the flange depth of the LGB wheels, as it is almost twice that of the Roundhouse wheels. I'm sure that if I could put LGB wheels on my Roundhouse locomotives then the problem would not exist.
The back to back gauge is spot on, and identical to my LGB locomotives. I have two Roundhouse locomotives (Criccieth Castle and Little John), both will run perfectly through the point if it's set to 'straight', however neither will run through any of my LGB points when they are set to 'curve'. Shimming the catch rail enables the locomotives to run properly through the points without hitting the nose of the points. If you are interested I'll take a photo of my brass shim to demonstrate what I have done. The brass shims act a bit like a spring and hold the locomotives wheels against the continuous curved rail of the point.I have never had a moments problem with running Roundhose Locomotives through LGB R1 Points, I have had 4 of them in my time plus visiting ones as well. Cannot understand what is going on here.
Back to Back Gauge is the critical thing and this is what could be different, but your Roundhouse Gauge should be sorting that out. But just in case, try to catefully measure between the inside of the Wheels on an LGB Locomotive. Use a Vernier Gauge if you have one. Then check this against the Roundhouse that is giving you problems. If it is not the same adjust. If it is use the Vernier to check the Back to Back on the points, the part where the wheels will pinch the frog and be pulled back from the Check Rail. Sorry if I am describing this in too much detail but I do not know your level of knowledge from this end of the ether! 1/2 mm difference in anything could cause you problems.
