spoz said:Warning - thread drift
Tag, good to see you up and about or at least communicating. How did the refit go?
Steve
Still partly on sticks but getting better every day. Am looking forward to walking and steaming again....
Steve
The locomotive should not be priming like this ? certainly on a half full boiler. I take it that the regulator will open fully and is not slipping round the shaft?? Otherwise we have a problem that will will have to work through a bit at a time and we will have to half and half ? ie check that steam at full pressure is coming out of the main steam pipe before it gets to the cylinders...cheshire said:So ... tried it with only half water. Running still no better. But I found a loose nut on one of the 2 pipes that come from the superheater to the valve chests. Tightened that up and now it doesn't leak but still no steam from the nuts however loose!! Plenty of oily water if you undo them lots though!!
