tramcar trev
I put up something in the ebay area then came up with a better solution viz:
Aaaaah dementia is setting in;
Mind you had I thought out my search string more thoroughly I would have found these. Only problem would be electronically triggering them. Maybe short out the play button after recording and supply power at 5V via an LM7805 across the motor supply, when the power comes on the thing emits its sound?
I guess at the price its not a great loss if it doesn't work....
Worth trying you think? ahh better add the url.....
http://www.ebay.com.au/sch/i.html?_from=R40&_sacat=0&_nkw=sound+recorder+module&_sop=15
Now these devices have the ability to accept whatever recording you throw at them (so its real sound and not digitally created sound) and there are some that can give up to 30 seconds and these are considerably cheaper than proprietary sound modules. Yes a reed switch (replacing the onboard press button) and a magnet/s judiciously placed along the track where the tram is required to ring its bell would trigger....
Maybe this should be cross pollinated to the sound section/ let me see if I can do this..... and YES I have done it without recourse to a moderators assistance.
