Just tried searching for it and only found the Card Covered stuff. I wonder if it is a different name? However it looks similar in its Brick Scoring Properties to HIPS which does appear to be UV Stable, but suffers from Heat Flexing in the Sun. Not a problem when used in a Shady Location.Very similar Henri.. A foam core, with a thin plastic sheet either side.. Commonly used for short-life advertising signs. - Name and party of local candidate at elections, 'for sale' signs,that type of thing.
It is very often not UV stable, but a coat of paint protects it.
It comes in various thicknesses.
You can use the edge of an old screwdriver (flat blade) to 'score' indentations in it to create a brick pattern.
This is the stuff I purchased - http://www.ebay.co.uk/itm/171981860...49&var=470867513940&ssPageName=STRK:MEBIDX:ITJust tried searching for it and only found the Card Covered stuff. I wonder if it is a different name?
The usual name for this foamboard is "foamed PVC", Foamex is the most common trade name in Britain.This is the stuff I purchased - http://www.ebay.co.uk/itm/171981860453?_trksid=p2057872.m2749.l2649&var=470867513940&ssPageName=STRK:MEBIDX:IT
Thanks Merlin. I got the idea from a visit to the Swindon and Cricklade Railway a couple of years ago. The original was part of a sloping raised bed surrounded by sleepers and that's how I intend to finish this off.Very nice Kieth. I do like the SVR plaque in pic 1 - very posh!
