trammayo
I just hate it when those on the boiler become droopy, saggy, and twisted. One such loco - and it is the Big haulers I'm describing - showed just how bad it can get ...
So, yesterday, as I set about servicing my stock, I finally tackled it...
I cut all the sections of rail out using side cutters, then trimmed the mountings with a sharp blade (so I could centre the drill bit - 2mm OD).
Then It was a just a case of drilling out the mounting brackets to take the 1.83mm brass rods (K&S - approx 300mm long before trimming to suit). ...
Nearside completed..
The other side was tackled in the same way. The plastic is rather soft and tends to clog the flutes of the drill bit as well as distorting - so the sharp blade is needed yet again. The result is a tightish hole which, if it had been metal, would have resulted in a sloppy fit! So of the three pieces supplied, I managed to make the cut bar for the front, plus four grab rails for the other "re-chassied" (RGS) loco.
More pics to follow (when I take them!).
