David1226
Select Home, Members, dropdown to Members MapOk I give up where is the map located please?
I can understand where you are coming from, but a marker on the right town might be useful, not ten miles away.Would you want 'all and sundry' to be able to see which road you live on????
I'm quite pleased not to have a marker on the map at all.
Cheers
PS I had to use Micosoft Edge to see any markers. They didn't appear at all when I was using Firefox.
Thanks David, I really should have been able to find that myself!Select Home, Members, dropdown to Members Map
Or follow the link in post 14.Select Home, Members, dropdown to Members Map
There was no need of a full explanation, you could have given us the abridged version.We use W3W a lot at work, really useful for locating pumping stations in The Fens. It will get you right to the spot, the only trouble is, it takes the direct route, so you may end up on the wrong side of a river
All right, if you're not careful, you get wetThere was no need of a full explanation, you could have given us the abridged version.
Its like that on purpose, its an approximate location for very obvious reasons.Also, many of the markers are many miles from where the member actually lives.
1:22.5 but you'll be close enough....can any one tell me the true scale loco's I am running , I want to get 2 drivers , is the scale 1:22
You may also find some figures listed for G scale as well as 16mm scale, go for G.@Casey posted this some time back.thank you
My address does indeed show the I.S.P. which is on the far side of town. Strangely Luxembourg doesn't have a marker, could this be A) Luxembourg is too small and a marker would cover it or B) something knows I do not have G scale anymoreDepending on how it is implemented, it might be by IP address (Internet /computer 'telephone number' for the uninitiated) which could show the location of your ISP..
