tac foley
The original post was for somthing simple & somthing we all can afford. The Thomas collection is a great start at just s few hundred pounds with great business like Smallbrook doing conversions @ £25:00 to make them look a little more realistic & simply run on a 45mm track.
Sir, you STILL have not told us what area of 'British train' modelling interests you.
Standard gauge or narrow gauge?
If standard gauge, then it's Gauges 1 or 3. Locomotives in either scale can go from simply 'quite' expensive to 'ludicrously' expensive, depending on your level of spending.
If narrow gauge, then the sky is literally the limit.
There are dozens of locomotives, ready to run or to build, and thousands of items of rolling stock. You can build a little loco for less than £100, and rolling stock for around £15 - 20 and up. If you are not too busy tomorrow, and live withing SAAF distance of Peterborough, the largest garden railway show in UK is on there at the Showground Centre - the last one ever
