Attaching figures - tips & tricks
curtis
27 Nov 2018
444
118
34
Jersey
Jersey
hsbagardenrailway.com
We've just come into possession of a fair number of preiser figures for the garden railway. I was wondering what people use for fixing them in position. Current ideas are for the following locations:
  • On cement platforms
  • On G Scale buildings (from Pola, Piko)
  • On rocks near the waterfall
I'd love to hear how you've approach this topic. I did have a search but struggled to find a specific thread on it.
Jazavalley
21 May 2022
106
21
64
Uk
England
Am an indoor modeller, but I am seriously thinking that all weather sealant for guttering in clear would stand the test of time
5,009
76
One of my favorite methods is to drill a hole in the leg and glue a pin or small length of wire in there. Then a hole in where you want the figure to be is drilled and the figure popped in. Bit tricky for cement slabs, get the smallest masonry drill you can find. With the odd extra hole you can move the figures about. On platforms the same pin method can be used in luggage to hide the holes thus giving chance to swop things around.
1,715
A small nail or pin through the feet, put into a corresponding hole put where you want the figures. Then they are easily removed. Or as Jazavalley says, some suitable exterior mastic
Edit: Obviously great minds think alike Jon and I posted at the same time!
5,009
76
Both typing at the same time!
mike
Master at annoying..
4,477
Rossendale
Hole drilled in the leg...a small metal nail/pin superglued the nail in the hole...drill hole were you want the figures
.clear.silicon if seated figures, ie inside a coach..or bench ect 20220422_145808.jpg
3,553
The beauty of clear silicon, as with loco nameplates, is that it can be removed. Usually, with no damage to the model(s).
LGB-Sid
19 Sep 2016
2,036
1,130
65
UK
I'm a drill a hole in the foot man as well and glue a small brass rod into the leg, then drill a hole to suit in platforms, buildings, or where ever. They are then easy to move around if required and also move back in if need be,
Dan
28 Jan 2010
663
52
Eastern MA, USA
I use steel wire not brass in the feet of the figures. One will ask why steel. It is due to the steel will rust and expand in the ground with rough edges over time, the brass does not do this.
1,715
But will you be able to remove them when required?
