Greg, that sounds like the 2-4-2T tank engine, "Lyn" and the black version, which I also took apart once. They have a split axle. The original Columbia tender engine does not.I just got hold of an exploded parts diagram, but it shows the axle as a split axle, 2 halves connecting to the center gear, which is much larger, so apparently there is more than one version.
Interesting. And I'm sure there's a third version of the axle on the later chassis with the brass gears!So again, it appears there is more than one version of this loco, and yes, I understand that the one here in question has a different driven axle.
Hi,Yep, that's the same as the one I fixed.
Here's the gear I got from Jerry:
The gent who makes delrin gears for Bachmann locos is Jerry Yeramian in Massachusetts. His email is girotek@rcn.com.Hi,
Just a quick mini hi-Jack, where can you buy this gear?
Thanks
For a gear that size? You guys do have a hard time.It might be worth you enquiring of Bachmann Europe? - Shipping, and other costs, will be a killer from the US..
Web Server's Default Page
service.bachmann.co.uk
