Y - you tackle from the bottom.
We had a choice at the Grammar School, so I opted out of rugby. Mind you if you were lucky you got to tackle one of the girls from The Convent about half a mile down the road. Funnily enough I ended up marrying one ten years later.That's what we were taught at school on the rugby field - hit the fleshy part for a soft landing and get your arms around the knees.
I think it's the era of when they were made.This saga continues, but I'm having trouble with the glazing. Some were originally stuck in with something softish/flexible, but not a silicon, somewhat harder than that, some with what looked like hot-glue, and some was a bit like Liquid-Poly, and some just clipped in. Having been advised that silicon would hold, that was the route I took but unfortunately some of it didn't: take, that is. I would advise folks not to mix glazing panels around your fleet. These coaches whilst they may all look the same, are not! There are minor differences that seem to pop up occasionally to bite one. I seem to have at least three incarnations amongst my six. Having got to over half-way through the build-up I wasn't about to start stripping down again and test which panels fitted best in which body, so I had to do small mods to what I had. It took time to get it right. The problems were two-fold, the hooks at the top, and the actual fit of the glazing bars into the window moulding. The first was relatively easy as the edge of the glazing can be slimmed with a file to suit the hooks and allow it to sit as close as possible to the body side, the second, almost impossible, so I made do with cleaning the edges off the glazing bars. It all seemed to help. We now await more silicon drying (which I'm leaving, clamped, for a day).
Many thanks I will keep trying.They can be quite tight. If painted whilst still assmbled it is easily possible that paint has got into the joint. I would apply a light prizing or twisting pressure, with a blade, along the sides to try and break the seal.
I can probably do you some on self adhesive vinyl as a short term measure if any help.With the thoughts of adding the railway logo, the easiest would be water-slide transfers. Whilst I have the artwork, I have no idea, or probably the equipment, to do the job. Pin-striping I'm still looking into.
Said Logo would be small, perhaps about the size of the spot above.
Anyone out there game for a commission? Need a couple of dozen.
They've got considerably fewer windows as well (Thank goodness!!
!). 17 - 12!
And about 3 times the price, certainly this side of the puddle.If and when you can get them.
Like the colors show up nice out side, I also repainted mine using acrylics, outdoor type, usually use Krylon rattle cans, but couldn't fine the correct color I wanted, never used a airbrush before so it was a little of a learning curve, also battery lit mine only I hid the batteries and external switch up in the clearstory using LED's. Thanks for the share, BillI have owned a few of these cars. Three were were new from the late lamented Garden Rail Centres. They were the ones with metal springs which rubbed on the axles in order to power lights. I moved them on at an Exeter Show some years ago. Three more were older and bought from someone (on the erstwhile GScale Mad Forum) who was giving up the hobby. This was at the time of the last postal strike, so took a couple of weeks to arrive!. These have battery boxes beneath for the lighting which is a more favourable idea in my view. One was used to make a static beanery (politely a Diner) car at my Flag stop. It was repainted, The final car was another new one, but green coloured, again from Andrew @ GRC.
The green one is untouched but the others were al painted in a livery similar to that of the Milwaukee Road. Little preparation was needed, other that a degrease type clean. The paints I used were the acrylic wargamers paints. This, with only one coat, is good but two coats of paint are more preferable. As this paint is a matt finish it looks better, in my opinion, a shiny finish highlights imperfections and looks unrealistic I believe. The diner is kept outside so need a refresher coat each spring, but the matt paint makes this a simple job.
My line is principally freight, but the J&S cars form an excursion train.
Just need to keep trying and spray in a large box laying on it's side, the lettering was done with my wife's Cameo silhouette which I have captured, BillSharp looking car Bill, the lettering is very clear and crisp. I can't use a rattle can or any spray method - most of what I spray goes to the wrong items!![]()
