Greg Elmassian
Guest
That test is marginal if you don't run anything bigger than a critter.... I run trains that pull several amps, some up to 10.
Your test would not isolate anything but an almost completely failed joint. That motor is probably drawing 1/2 amp or less.
If you don't want noticeable drop in speed, you should really test at double the current the actual train draws. A noticeable slowing can be observed with as little as 1-2 volts "lost".
