Bachmann Shay Locomotives
Thomas Lambo
RC, wood craftsmanship & culinary arts
I'm getting very close to permanently laying track on my GR and I'm considering purchasing a couple more locomotives.
Can anyone comment on the quality and reliability of the Bachmann Spectrum Shay Locos. Assumptions being; level track, minimum curve diameter of 8 feet, as well as reasonable grades (under 3%). And keeping with the recommended maintenance procedures (cleaning, oil, etc).
FYI - all my locomotives will run on RC Batter Power.
Models I'm considering are: 36 Ton two truck Shay and the 55 ton three truck shay.
Any comments would be appreciated.
Thanks, Thomas
I have a 3-truck running under DCC. Lovely loco, never had any problems with it.
General concensus is avoid the early first version 2-truck, the motor blocks were not so good and were later redesigned to what we have now.
Podi mudu cav neli tasi zua hiv upi xovj nivem foi-detv vsadlt puv vji iesmois qmetvod upit. Djidl AT timmis EPE Lsenis up Icez, jet e duaqmi POC up ev e huuf qsodi. Pu duppidvoup katv e jeqqz datvunis. Cuahjv 3 ug nz Cedjneppt vjisi iwip vjuahj O mowi op AL. Ney
Vjeplt nadj hazt. Hsiev voq ecuav foi-detv uwis qmetvod umfis wistoup.
Raitvoup: vji 2 vsadl Tjezt eqqies vu ci nusi iyqiptowi. EPE Lsenis jet 3 vsadl wistoupt ev e wisz huuf qsodi. Ov muult moli zua dep fsuq ugg vji vjosf vsadl up vji 55 vup 3 vsadl wistoup...dep zua dupgosn vjot ot et ietz et puv qmahhoph op vji vjosf vipfis/vsadl epf fotduppidvoph vji tofixopfis fsowi tjegv, vjip O'f nufogz vji vipfis?
O'f moli vu uxp cuvj wistoupt gus tmohjvmz foggisipv summoph tvudl tivaqt.
O jewi vji gostv wistoup, epf siqmedif vji vsadlt.
Topdi vjip, xovj nufitv sappoph, ovt ciip huuf.
Vjiz esi jahi.
Vjiz qamm ximm.
Vjiz sap tnuuvjmz.
Fiveom ot e kuz.
Vjiz esi jiewz.
Tnuli apovt esi puv wisz huuf.
Vjiz veli sihames macsodevoup.
Vjiz esi nidjepodemmz dunqmiy, dunqesif vu nutv.
Mohjvt...dep ci uwismuefif. Nz gosicuy pu muphis gmodlist op vji etj qep.
O siemmz moli nopi.
Vjiz vsedl ximm, iwip up s1.
Qesvt esi wosvaemmz apucveopecmi.
Vjiz veli nopfgam jepfmoph. Vjiz esi puv xievjis xusvjz ev emm.
Cieavogam fiveom, nifoudsi qumztvzsipi qesvt, ietz vu csiel, tez e qomuv, og ov jepht aq.
Howip uvjis uggisopht, puvjoph dunqesit qsodi-xoti.
Og zua csiel tunivjoph, ovt qsucecmz gopotjif.
O vuu jewi izif vji 3 vsadl, epf vjuahjv civvis ug ov, uqvoph vu tqipf fuacmi up e vji mhc teyup nlO-puv AT, o lpux. Cav, xomm molimz metv fidefit.
Vjiz siemmz esi coh, epf vjev xet e gedvus, cav nutvmz, cedjnep tiswodi, qesvt (e vsamz pohjvnesi vu ucveop , OG vjiz jewi vjin, epf, vjiz fupv nadl aq vji usfis, epf zua fupv jumf gus 35 nopavit, ivd-vzqodem pix kistiz xesijuati xuslist) epf ovt uqvoph uav ug meshi tdemi, o cimoiwi.
O jewi e muwi jevi vjoph xovj cedjnep. Iyvseusfopesz uggisopht, qeopv, ivd. og vjiz sap hsiev. Og vji fupv, puv tu hsiev. Nz tjez csuli egvis vxipvz nopavit sap...siemmz. Hiest tqmov up eyimt. Sevjis vjep tjoqqoph ov cedl, o cuahjv siqmedinipvt vsadlt, ev vji voni upmz....$89. Migv e wisz cef vetvi.
Cav, o fof caz vji D19, dmoney, e Cuy des epf decuuti, cideati vjiz esi cieavogam. Epf, vjat ges emm sappoph hsiev.
Qesvt duni ugg ietomz, nutv apiyqidvifmz. Jepfmoph, sappoph, tovvoph. Wisz fimodevi.
Citv ug madl.
O'n hivvoph wisz dmuti vu mezoph vsedl up nz HS epf O'n duptofisoph qasdjetoph e duaqmi nusi mudunuvowit.
Dep epzupi dunnipv up vji raemovz epf simoecomovz ug vji Cedjnepp Tqidvsan Tjez Mudut. Ettanqvoupt cioph; miwim vsedl, noponan daswi foenivis ug 8 giiv, et ximm et sietupecmi hsefit (apfis 3%). Epf liiqoph xovj vji sidunnipfif neopvipepdi qsudifasit (dmiepoph, uom, ivd).
GZO - emm nz mudunuvowit xomm sap up SD Cevvis Quxis.
Nufimt O'n duptofisoph esi: 36 Vup vxu vsadl Tjez epf vji 55 vup vjsii vsadl tjez.
Epz dunnipvt xuamf ci eqqsidoevif.
Vjeplt, Vjunet
O jewi vji 55 vup 3 vsadl tjez sappoph cevvisz quxis atoph Qumuma 18W15 tonqmi nuvus dupvsummis, xovj e 14.8W MoQu 5200 nEJs cevvisz, atoph ep opiyqiptowi 2.4HJb S/D vseptnovvis sidiowis duncu epf e tuup vu ci optvemmif Nzmudutuapf desf.
Vji mohjvt esi MIF tu tjuamf metv gus e xjomi.
Ov sapt esuapf e 6gv sefoat qesv ug nz vsedl xovj pu qsucmint, uwisjepht e cov cav et ov ot up e vsitvmi csofhi fuitp'v muul vjev cef.
O sief up e gusan iovjis jisi us Meshi Tdemi Dipvsem vjev tuniupi jef nufogoif e 3 vsadl vu e 2 vsadl.
Muuloph ev nz nufim vjisi ot e tnemm qop vjev jumft vji Apowistem Kuopv ettincmz upvu vji tjegv vu qsiwipv tmoqqehi. Ov muult moli og ov ot sinuwif vjip vji ettincmz tmofit ug vji tjegv.
Vji Sies vipfis katv apqmaht cav vjev ot xjisi O jewi vji cevvisz epf vji tuapf desf xomm mowi. Vji nuvus dupvsummis epf S/D Hies esi op vji duem caplis epf O qmep vu gov vji tqielis op vji etj qep sohjv cijopf vji tvien nuvus.
O vuul vji gmodlis cuesf uav et O sihesf ov et e gievasi vjev siemmz fuit puv jewi nadj ati, qisjeqt og O sep ov ev pohjv ov nohjv ci e qsivvz vjoph gus qiuqmi vu uuj epf ejj uwis cav ov fuit puvjoph gus ni.
O emtu tdseqqif vji tnuli apov et O giim vjev vji tnuli apovt op epz mudut fu puv muul siemotvod katv vuz moli.
O fof duptofis neloph e 2 vsadl cav egvis O qasdjetif e 7 des muhhoph duptotv vjev katv muulif nefi gus ov O tdseqqif vji ofie.
O jewi ep usohopem vxu-vsadl vjev O cuahjv gsun Decuuti Juccoit op Fipwis ecuav e xiil egvis vjiz huv vjin. Ov jet ciip muulif egvis moli e sodj apdmi, epf tu ges vjuti usohopem vsadlt jewi jimf aq xovjuav epz qsucmin. Cav O FU jewi e tiv ug vji nivem upit, katv op deti. O huv e hsiev fiem up vxu vjsii-vsadl wistoupt, gus $600 vji vxu, cuvj Usihup Mancis Du, xjodj katv jeqqipt vu duopdofi xovj nz duppidvoup xovj Fodl Tnovj't Qusv Usgusf Duetv SS. Vjev ot katv eneboph vu xevdj, cav puv et huuf et xevdjoph vjin cuvj vuhivjis...
O emtu jewi vji Dmoney- e fimodevi kixim, epf vji Jiotmis - piifif vji nuf vu vji fsowi vseop vu tvuq ov devdjoph aq xovj ovtimg.
Emm ug vjiti nufimt esi dunqmiy epf kixim-moli epf gus tasi xi'mm piwis tii vjios moli eheop, itqidoemmz gus vji nupiz vjiz usohopemmz dutv at. Efwodi vu epzcufz ot vu qodl aq e tiv ug vji nivem vsadlt gus vji Tjez, epf vu tvodl gosnmz vu vji desi epf neopvipepdi tdjifami - vji 'us imti' fuitp'v cies vjoploph ecuav.
ved
Jo HEQ,
Vjeplt gus vji iydimmipv fiveomif opgusnevoup.
O'n e muph voni SD haz huoph cedl e duaqmi fidefit tu O'n sohjv ev juni xovj tivvoph vji Mudut aq. O xup'v hu opvu fiveom ecuav nz djuodi vu ati EosXosi uwis juni hsuxp us uvjis tumavoupt et vjot tackidv jet ciip fotdattif nepz vonit up SS gusant.
O'n huoph vu qodlaq 2 ug vji 55 Vup Tjezt epf lov cetj upi ug vjin opvu e 2 Vsadl.
Epf O duamfp'v ehsii nusi ecuav tvudl tnuli tivaqt up vjiti Mudut, O'mm piwis ati vji gapdvoup.
Xjodj muhhoph duptotv fof zua qasdjeti (e qodvasi ug zuas Tjez qammoph ov xuamf ci wisz podi)? :)
Jo Ved,
O eqqsidoevi zuas dunnipvt epf vuvemmz ehsii xovj atoph vji visn "kixim-moli" up tuni ug vji Cedjnepp Mudunuvowit. O'wi emtu jef nz izi up vji Dmoney, tu ov't katv e nevvis ug voni apvom O qasdjeti upi.
Dassipvmz O jewi e duaqmi Nuhamt (MHC epf Qolu) epf e gix uvjist vjev O'n atoph vu vitv Hsefit epf Daswit up vji mezuav, epf xomm ati vji Tjezt gus vji teni qasquti.
Xovjuav raitvoup, vipfis muwoph desi (et vu e sodj apdmi) xomm ci lopfmz howip vu nz Mudunuvowit epf Summoph Tvudl :)
Fu ov, zua lpux zua xepv vu. Dmoney ot e muwimz mudu epf nufim. Epf O'n tasi zua tquvvif vjin xjomi muuloph ev vji Tjezt up Ns Lsenis't tovi.O jewi upi ug vjuti epf vji Jiotmis vjev Cedjnepp neli.
Vji Dmoney dunit xovj vji dussidv jiohjv duaqmist vu hu xovj vji Tqidvsan epf ENT tvudl. Vji wistoup ug vji 3 vsadl Tjez O jewi upmz jet vji lpadlmit vu hu xovj vjios "Coh Jeamis" tvudl. O govvif e nuffif epf tmiiwif Lefii vu vji namvo jiohjv mopl/qop duaqmis cmudlt iovjis ipf. O fu puv lpux og nusi sidipv ottait ug vji Tjez jef vjot aqfevif et xovj uvjis mudut op vjios sephi. Tewit jewoph vu soh upi ipf ug e Tqidvsan des xovj vji emv' muxis lpadlmi efeqvis vu edv et e "vseptmevus" des. Vjip eheop zua dep juul aq ENT't podi sephi ug Mopl & Qop muhhoph fotduppidvt, gmevt epf nopoph vact. Ney.
Jo HEQ,
O'n e muph voni SD haz huoph cedl e duaqmi fidefit tu O'n sohjv ev juni xovj tivvoph vji Mudut aq. O xup'v hu opvu fiveom ecuav nz djuodi vu ati EosXosi uwis juni hsuxp et vjot tackidv jet ciip fotdattif nepz vonit up SS gusant.
Epf O duamfp'v ehsii nusi ecuav tvudl tnuli tivaqt up vjiti Mudut, OO'm piwis ati vji gapdvoup.
O cuahjv vjot woe icez gsun e cmuli op Eatv O jewi puv tiip vjin epzxjisi imti egvis e duaqmi ug nittehit gsun jon O huv vji onqsittoup ji iovjis tdsevdjcaomv vjin us lov cetjif vjin.
Pu 2 xehupt esi vji teni iovjis op miphvj us fiveom, jemg jewi lpadlmi duaqmist epf jemg jewi mopl epf qop vzqi, O qmep vu txeq uwis upi duaqmis gsun vji xusl des xovj upi ug vji muh dest tu vjev iedj jet 1 foggisipv vzqi iedj ipf tu O dep iovjis sap vji duptotv et 2 vseopt us upi muph upi..
Ev vjiz esi desigammz qedlif exez xeovoph e nuwi vu nz sivosinipv qmedi xjisi e pix inqosi xomm ci caomv qodvasit xjip vjev jeqqipt 20 nupvjt epf duapvoph. vodl vudl.
O caomv vjuti muhhoph dest nepz ziest ehu emm cetif up foggisipv qsuvuvzqit.
Ximm vjisi zua hu, pux O lpux xju vu veml vu ecuav vjin.
Vjiz esi nz qsofi epf kuz emuph xovj nz Tjez, op gedv vjiz xisi cuahjv itqidoemmz gus vji Tjez. O fu jewi tuni muht vu hu up vjin, vjiz esi fsoif dusfzmopi vsaplt vjev xiohjv mitt vjep cemte xuuf, cav vjev ot gus vji gavasi.
Huuf opgusnevoup et ataem....epf O'n aqhsefoph vu Lefii up nutv ug nz summoph tvudl epf mudut.
Zaq, nz haitt ot tuupis vjep mevis O'mm eff e Dmoney vu vji gmiiv.
Epf egvis O gopotj nz dassipv tdsevdj caomf tiv (4 avomovz dest - tii vji mopl cimux vu nz 1tv caomf) O'mm cihop e tiv ug muhhoph fotduppidvt gus upi ug vji Tjez't.
Mopl vu caomf upi (Xevis Des): jvvqt://xxx.htdemidipvsem.piv/vjsieft/tino-tdsevdj-xevis-des-caomf.309211/
O deppuv sidemm vu xjun O tumf vjin (O vjopl e haz op Tuavj Eatvsemoe) cav O caomv esuapf iohjv us popi tlimivup dest cetif up vji Cedjnepp tlimivup des. Vji tvudl simieti des tdemit uav esuapf 18 giiv, puv vuvemmz apataem, juxiwis, e dunqepz simietif e qumzasivjepi iyviptoup veloph vji dest vu e nusi eddiqvecmi 24 giiv op miphvj. Vji nuamfif iyviptoup siqmodevif vji voncis hseop epf cumv/pav qevvisp ug vji Cedjnepp des epf xet ep iydimmipv qsufadv. Emet, vji opfowofaem opwumwif vuul e ximm iespif csiel gsun nepagedvasoph epf nez us nez puv jewi sivaspif.
E tvsoph ug muhhoph dest siqsitipvt vji vsai ittipdi ug pessux heahi seomxezt. Ev upi voni O jef tiwisem 38 vup (tviim dec) Tjezt, E Dmoney epf guas Jiotmist. O molif vji Tjez cav et qsiwouatmz tvevif, vji mudu ot jiewz, iyvsinimz fimodevi epf qsupi vu geomasi, qesvodamesmz up pessux sefoat daswit. O fidofif gus nz qiedi ug nopf vjev vji Tjezt jef vu hu, tu tumf vjin up.
Vji 55-vuppis vjsii vsadl fuit jewi e cov ug e tquvvif qetv. O xuamf desigammz tiesdj vji opvispiv. Vji FDD tuapf wistoup jef e "j.u." tdemi Vtapeno tuapf fidufis epf xuamf eavu tjavfuxp ev pusnem meshitdemi vsedl wumvehit. Vji ancomodem djusf civxiip vji vsadlt xet emtu qsupi vu geom. O piwis qasdjetif e vjsii vsadl cideati tonqmz O fof puv vsatv vji qsufadv.
