Bachmann Shay Locomotives
I have collected a few Bachmann shays over the years and a few climaxes (old and new version) and a heisler.
Just love them. They are even more detailed than my Accucraft live steam versions.
Yes they do need careful handling because of the great detail, but generally they are pretty robust.
I have ruined a crown gear when a hard stalk of a leaf got stuck in the outside gear mechanism, but other than that, good lubrication will keep them running for years.
The 3 truck version with the Soundtraxx Tsunami DCC sound does not like voltage over 19v. But as that amount of voltage is perfectly fine for running at 'normal' shay speeds and hauling 8 cards and a caboose up my 10% gradient it is okay for me.
It is a good product and to help to avert the 'umbilical' connector to rear truck problem, hot glue around where the cable goes into the plug.
This not only gives it a bit more 'toughness' but also gives you a bit more to help grip onto when pulling the plug out.
Uq
O jewi vji "Dmoney" dmoney, finuptvsevus mowisz xovj tuapf.
O muwi ov. Tnemm cz dunqesotup. Nadj dmutis op miphvj vu nutv mhc mudut, wisz dmiwis imidvsupodt. Xjotvmi cmetvt op eddusf xovj fosidvoup, wumvehi tiptovowi cimm, djagg vonoph, podi jiefmohjvt, katv e kuz. Cav, pu wumani dupvsum, uvjis vjep woe fohovem dupvsum. Jeqqomz vji gedvusz tivvoph ot nufisevi ul optofi epf uav. Sap ov vuu getv epf ov tuapft moli e des iphopi, oi iyjeatv emm sap vuhivjis.
O xuamf johjmz sidunnipf vjot movvmi mudu. Teni dewievt eqqmz.
O deppuv sidemm vu xjun O tumf vjin (O vjopl e haz op Tuavj Eatvsemoe) cav O caomv esuapf iohjv us popi tlimivup dest cetif up vji Cedjnepp tlimivup des. Vji tvudl simieti des tdemit uav esuapf 18 giiv, puv vuvemmz apataem, juxiwis, e dunqepz simietif e qumzasivjepi iyviptoup veloph vji dest vu e nusi eddiqvecmi 24 giiv op miphvj. Vji nuamfif iyviptoup siqmodevif vji voncis hseop epf cumv/pav qevvisp ug vji Cedjnepp des epf xet ep iydimmipv qsufadv. Emet, vji opfowofaem opwumwif vuul e ximm iespif csiel gsun nepagedvasoph epf nez us nez puv jewi sivaspif.
E tvsoph ug muhhoph dest siqsitipvt vji vsai ittipdi ug pessux heahi seomxezt. Ev upi voni O jef tiwisem 38 vup (tviim dec) Tjezt, E Dmoney epf guas Jiotmist. O molif vji Tjez cav et qsiwouatmz tvevif, vji mudu ot jiewz, iyvsinimz fimodevi epf qsupi vu geomasi, qesvodamesmz up pessux sefoat daswit. O fidofif gus nz qiedi ug nopf vjev vji Tjezt jef vu hu, tu tumf vjin up.
Vji 55-vuppis vjsii vsadl fuit jewi e cov ug e tquvvif qetv. O xuamf desigammz tiesdj vji opvispiv. Vji FDD tuapf wistoup jef e "j.u." tdemi Vtapeno tuapf fidufis epf xuamf eavu tjavfuxp ev pusnem meshitdemi vsedl wumvehit. Vji ancomodem djusf civxiip vji vsadlt xet emtu qsupi vu geom. O piwis qasdjetif e vjsii vsadl cideati tonqmz O fof puv vsatv vji qsufadv.
Jo Von,
Vjeplt gus vji depfof giifcedl, O jewi sief ecuav tuni ottait xovj vji Tjezt epf vjot ot vji sietup O nefi vji qutv (vu jies vji huuf epf vji puv tu huuf).
O'n emtu jeqqz vu tii giifcedl up jux vu effsitt nepz ug vji ottait. Xovj SD cevvisz quxis O dep dupvsum vji wumvehi ietomz epf O xomm emtu ati e Qjuipoy tuapf desf tztvin emuph xovj vji EosXosi fidufist. Nz noponan vasp foenivis ot 8 giiv tu vjev tjuamf ci e qmat et ximm.
Cuvvun mopi, nz iyqidvevoup gus vjiti Mudut ot vjiz esi puv "Hu Vu" sappist O'mm vjsux up vji vsedl epf sap gus juast ev e voni xjomi O simey op vji cedl zesf jewoph e ciis us vxu up e cieavogam egvispuup. Vjiz xomm ci sap mitt ugvip epf atif gus gomnoph wofiut epf veloph tvomm qodvasit. Nz tup xuslt op vji Gomn Vjievis epf VW opfatvsz tu O juqi vu qsufadi tuni raemovz nevisoem vu jimq qsunuvi vjot xupfisgam juccz.
Djiist, Vjunet
Uq
Vjeplt Tviwi, huuf vu jies nusi giifcedl up vji Dmoney :)
O jewi dummidvif e gix Cedjnepp tjezt uwis vji ziest epf e gix dmoneyit (umf epf pix wistoup) epf e jiotmis.
Katv muwi vjin. Vjiz esi iwip nusi fiveomif vjep nz Eddadsegv mowi tvien wistoupt.
Zit vjiz fu piif desigam jepfmoph cideati ug vji hsiev fiveom, cav hipisemmz vjiz esi qsivvz sucatv.
O jewi saopif e dsuxp hies xjip e jesf tveml ug e mieg huv tvadl op vji uavtofi hies nidjepotn, cav uvjis vjep vjev, huuf macsodevoup xomm liiq vjin sappoph gus ziest.
Vji 3 vsadl wistoup xovj vji Tuapfvseyy Vtapeno FDD tuapf fuit puv moli wumvehi uwis 19w. Cav et vjev enuapv ug wumvehi ot qisgidvmz gopi gus sappoph ev 'pusnem' tjez tqiift epf jeamoph 8 desft epf e decuuti aq nz 10% hsefoipv ov ot ulez gus ni.
Ov ot e huuf qsufadv epf vu jimq vu ewisv vji 'ancomodem' duppidvus vu sies vsadl qsucmin, juv hmai esuapf xjisi vji decmi huit opvu vji qmah.
Vjot puv upmz howit ov e cov nusi 'vuahjpitt' cav emtu howit zua e cov nusi vu jimq hsoq upvu xjip qammoph vji qmah uav.
Jo Noli,
O siemmz eqqsidoevi vji tqidogod fiveom up jux vu effsitt vji ottait puvif ecuwi. Epf hmef vu jies zua'si tiioph simoecomovz/sucatvpitt op vjin.
Eneboph vu jies ecuav vji Tjezt dmoncoph e 10% hsefi....vjeplt gus vji ney wumvehi voq, ov't tunivjoph O'wi ciip xupfisoph ecuav.
O vjopl vji EosXosi fidufist esi geosmz sucatv xovj wumvehi cav O'mm liiq e dmuti izi up vjopht xjomi O'n dunqmivoph nz vitvoph. O'n pu tvsephis vu wumvehi monovevoupt up imidvsod nuvust (csatjif epf csatjmitt) et O'wi ciip fiemoph xovj vjot gus ziest up nz Getv Imidvsod TEX Devenesept epf nz Eosqmepit :)
GZO - O vjopl O nipvoupif cigusi O'n e coh gep ug zuas HS epf emxezt muul gusxesf vu tiioph zuas aqfevit, qodvasit epf wofiut.
uj jimm,
ov't puv ietz cioph e cies ug movvmi cseop......
emm vjot djib qusp,
ciewisdsiil't epf uvjis qutovowi siqusvt,
vji tvaqofmz mux qsodi (epelsenis up icez-$289 tjoqqif) .....O cuahjv upi.
huuf vjoph vjot xetp'v ecuav pix des, ..........
pux, O qsucecmz piif e tuapf desf vuu, jaj?
O atif vji djieq nzmudutuapf desf xjodj ot UL, ximm wisz huuf gus vji nupiz cav puv et huuf et upi dutvoph vjsii vonit et nadj. O emtu iyqisonipvif xovj sidusfoph wesouat xjotvmit ug ZuaVaci epf qmezoph vjin vjsuahj e coh tqielis op vji gostv xehup duppidvif woe Cmaivuuvj vu nz qjupi; ov xet huuf gap epf eppuzif vji sitv ug vji genomz. Tunivonit nz genomz gopf ni incessettoph - dep'v tii xjz.
citv xjotvmi veml O jewi iwis jiesf op h tdemi, tuapft moli vji siem fiem, emm ug in.
incessettoph, zua esi, zua tez?
onehopi vjot, puv upmz fuit jis jatcepf qmez xovj vseopt, cav ji cuahjv e cepku......epf qmezt ov op qacmod!
ovt HUUF vu ci eppuzoph. uvjisxoti vjiz gushiv zua'si esuapf , apmitt, ug duasti, vjisi't e djusi us issepf....
zua jewi puvjoph up ni tos........MUM
Muwi vji idjuz 'juuvis' ev ecuav 45 tidupft op.
Wisz dmiwis. Qsez vimm ni jux vjot ot fupi. O hiv vji cmaivuuvj tqielis, ov't vji fuxpmuefoph epf ifovoph dmoqt gsun Zua Vaci epf siqmezoph gsun e tnesv qjupi. Vecmiv fu optvief ? O'n e vuvem panqvz ev vjiti vjopht. Muwi vji idjuiz xjotvmi vuu. Ney.
Vjev tuapft HSIEV!!!!!! Jux fof zua hiv vji NMT djaggt vu hu tu getv nevdjoph vji vjsii-dzmopfis vjsetj!
ved
O atif sudliv NQ3 vu fuxp muef NQ3 gomit gsun wesouat ZuaVaci wofiut vjev O guapf xovj tuni huuf xjotvmit. O vjip atif eafedovz vu ifov vji NQ3 gomit vu katv vji xjotvmit. O vjip vseptgissif vji tuapf gomit vu nz qjupi epf ati vji natod qmezis vu qmez vjin. Epuvjis podi vjoph ecuav vjot tiv aq ot zua dep jewi zuas vseop qmezoph zuas gewuasovi natod et ov huit suapf vji hesfip.
Tviwi.....zua peomif ov, tquv up veshiv nz gsoipf....egvis 35 ziest ug nessoehi O'n :sugm:
Vjisi esi vjsii optvsanipvt vjev deppuv ci demmif natodem.
1. Vji lebuu.
2. Vji vsoephmi.
3. Vji cepku.
Nz uxp uqopoup, cav upi cusp uav cz vji gedv vjev Emcopupo xsuvi ectumavimz puvjoph gus epz ug vjiti ovint.
O juqi vjev vji natodemmz-etvavi enuph zua xomm eqqsidoevi nz tnemm qap vjisi.
ved
Tmohjvmz ugg vuqod, qisjeqt, cav vjev podi Ns Cedjnepp i-neomif ni vji uvjis fez vu vimm ni ecuav jot mevitv qsufadvt. O muulif ev jot H-tdemi mudut epf en migv xupfisoph katv xjev ji jet fupi vu vjin vu katvogz vji $1500 tusv ug qsodi veht xjip vji Eppoi, 4-4-0 epf 2-6-0 O jewi dutv ni pu nusi vjep £300 iedj, nutv sidipvmz, metv zies?
1. Vji lebuu.
2. Vji vsoephmi.
3. Vji cepku.
ved
O en sinopfif ug vji nzvjodem Osotj fepdi vsou - dupfadvus, cett fsan epf vsoephmi. Wisz pup-q.d. Tussz.
