Greg Elmassian
Guest
It's very important for a transmitter to have an antenna that it resonates with. 1/4, 1/2, and 5/8 waves are typical. All have different radiation patterns and different requirements for a ground plane.
On the receive side, again you want a resonant structure to receive the signal "most strongly"... and again it should be (typically) an integer sub multiple... mainly for practicality.
The longer the antenna (provided it is a sub multiple or multiple of the wavelength) the more gain.
There is an exception in the R/C industry (does not hold for Aristo) recently though, by tuning their systems to a 40" wire, to try to use the same antenna for 27 and 72 MHz... weird.
So, antenna length is important on both ends, and in the higher frequencies, polarization. You can look this up anywhere, but please on an electrical engineering site, by engineers. I have one engineer whose sole function is designing antennas, and built my first high gain Yagi antenna tuned for my favorite FM station in 1973, and am an amateur radio operator.
