Havent got that far yet Neil
however the Garratt ( 2 Stainz), has two of these gels on board the engine & will pull as much as I can put behind her,
only limitation is wagons pulling off track on the corners, with the weight of the whole train behind
To get maximum traction out of T Urn I will probably have to add some ballast under the front of him
The wagon has one bogie with brass side frames, & one with aliminium frames
On my free rolling Gravity test off the Bank , it will travel almost as far as the Aristocraft bearing bogied wagons.
So I think rolling resistance, carrying that weight is as low as I can get it
Will have to do some tests
