Battery Conversion of a Ten Wheeler
Work on my conversion has moved another step closer to completion, with a "spray job" and decals added, time to start adding details :)
Having painted my 10 wheeler, I am now starting to assemble and detail, here is the progress so far - Amazing, you cannot hide anything from the camera, and it seems the loco body may need a small flash of paint as it seems to be a be light on the chimney:
Are you sure it was not reflected light from the wall?
Try moving the loco to natural light, and check..
The 10 wheeler is not quite finished, a little extra detail is needed, however as the whether is dry and bright I thought a quick play test run would be in order.
A couple of minor issues, the first is the "lightness" of the front bogie, a known issue so a little extra weight. The second was the chuff, I am using the Annie chuff sensor as advised connected to a MLS, and though the sound is aligned, occasionally usually when starting off I get a double chuff, and then it settles down, and again occasionally it misses a chuff, my assumption is that it is the sensor, being mechanical in principle, though any thoughts would be appreciated.
A short video of the test, pulling 2 JS coaches up my 1:25 gradient without issue, most of my other locos often struggle, and this is with a Li-Po 3S so only 11.1 volts :)
As you say, a mechanical chuff - trigger.
You will get a little contact-bounce and the occasional miss of a beat.
I have found (certainly, on brand new models) that the efficacy of the chuff, gets better over time.
Give the contacts a gentle clean. There is very little current involved, so the slightest bit of grease, will have an adverse effect.
As the chuff is principally mechanical, I don't know whether the MLS could act slightly strangely if the axle actually stops in the chuff actuating position.
If so, as the switch has a little bit of a dwell angle, it may give that double chuff - dunno, just guessing. I don't know if it happens on my Connie, as I've never been that alert :oops:
I advocate not adding weight. The problem is the rigid long wheelbase. Underneath there are 2 metal strips down the central spine that pick up power and align the axles. 2 nylon clips hold them in place - one has an arrow pointing forward, in case you are using track power. Remove the 2 nylon clips, and the whole thing becomes floppy and equalized. It will stay on any rough track. Mine worked for years without any additional weight.
I imagine you have cut the wires. However, if you ever visit a layout with track power and want to run your loco at the same time as the track power is on, do put some insulation (electrical tape, etc.,) between the 2 metal strips, or you will upset your host by making random short circuits! Ask me how I know.
Fred, interesting i will look in to this :)
Hi Jimmy
That's a really nice paint finish on your 4-6-0. Would you mind letting me know what paint you used and where you bought it from.
And secondly I was wondering who you purchased your decals from. I need some for my Connie and was hoping that I can source them in the UK. Stan Cedarleaf's decals are excellent but post and import duties are against it.
Tim
Hi Jimmy
Tim
Hi Tim, the paint is Hycote Double Acrylic, colour is BMW Black 086 (no lacquer required) bought from The Range. The decals are from Stan, total cost inc p&p etc $58.00, the work included some page work and design, I was very happy, I just supplied my outline crest, and letting type and size. Stan then sent a proof sheet, a couple of minor adjustments. From starting an email "conversation" to receiving the finished items was less than 2 weeks.
The loco has is now considered complete, a test run has been carried out but poor lighting has prevented and videos of this. Below is a photo of the complete loco, and also a link to my blog providing details, if you have any questions please ask :)
Bachmann 10-Wheeler Battery Conversion – Tumble Down Falls
Aha Jimmy, possibly just one small job a plate between Tender and Loco. I have used Pond Liner with success, but a bit of stiff black bin liner can also work. To help with curves helpful to make the unstuck end curved. Though this is a pic of a 00 loco the concept worked on my US LGB 2-6-0.
Hi Jimmy, another question, if I may.
A nice looking ladder on the rear of the tender. Did you scratch build this or source it from a supplier? Interested to know, as I need some!
Best,
Tim
Hi Jimmy
Sorry to keep asking, but I wonder where you sourced the ladder on the rear of the ten wheeler tender. It is just what I need.
I tried to get some paint from the Range, but they are out of stock. Will try again next week.
Lastly would you mind telling me what you used to seal Stan's decals? I just want to make sure that I don't get something that either affects the paint or the decals.
Many thanks.
Tim
Hi Jimmy
Many thanks.
Tim
Tim, sorry missed the question first time. The ladder came from S&D models, it is part of a kit for Bachmann Caboose, the paint is Rustoleum Crystal Clear, however having had issues previously, leave to dry for a few weeks.
Having run the 10-wheeler a few times, I found that with the LiPo 3S 11.1 volts, I was running on or near full throttle, which did not mean i had any "extra" power. So I decided that I would move to a 4S Li-Ion, taking consideration of the safety concerns of the soft shell LiPo. The current Rx is a Deltang Rx66, and as most of you are aware don't like much over 13 volts, so I decided that I would go for the Micron MR001a and a Mtronix Viper 10A HV ESC. I also decided to go for the premium MLS sound card.
As advised the downside to the viper is the heavy duty wires, and fixed end connectors, however some adaptation and it still fits and works:
All my electronics are held in place by Velcro, which allows removal and repositioning.
