or the next time gauge 1 is 1:32 and the track should be 44.45mm. For gauge 1 locos and stock take a look at ebay.de as Märklin are big in this scale but be warned, the prices will make you go WHAAAAT?
Yes i know the prices are WHAAAAT! and no question mark.
Thats why i am so eager on diy builds, especially the bigger ones and live steamers....they go up really quick.
Also there are some loco's that i want that are not even for sale or existing in 1:32.
Red devil for example or some Eeries or some Pasific's, Chesapeake let alone the AA20, drowling again, sorry.
even a little correct 5 meter radii turn out starts at 200 euro.
if you got some time, let your brain get twisted by some scale lists.
scales
Yes, thanks, i stick to 1at32 scale, it is very easy to calculate to mm, and not others.
I made a screen copy from your site so i can see before a bidding or buy now what i dont want.
The era of "just" n h0 or g scale is over, g scale was in my mind always lgb, big and ruf.
beware if you look on german ebay, don't look for spur 1 / spoor 1 - for that they charge you a leg and an arm!
Maerklin maxi and all the other toys, that sail under the name Spur 1 are for millionaires only.
We dont have kids, just some dogs all is good with the house and bills and we can not take the money thru the gate of st Peter.
But yes if you want to have some nice loco's, it will cost you a lot.
But time you can not make, money you can, i will hobby in my shed.
"grootspoor" i know them very well, they are not even 30 km away from me.
I find them pretty expensive.
On ebay and such i can buy some experimental loco's, even thinking about to buy only for the frame and rebuild the frame for a other loco'.
We will see, first a lathe with a router from HBM.
Probably for
justme igor
Piko may be his best bet
Piko, i will refine my search for those ones, lets see whats coming up.
Pricewise these days on the up though older loco stock with non plated wheels much cheeper and very suitable for conversion to battery power
Exactly what i would like, non of that dcc or computer programs, easy on converting to battery power, there is a lot of track to drive in the future.
For wheels, cylinders and such i am glad i can sand cast...
3d printer to make a bigger model, put into sand, cast metal, work with a lathe and a router for grinding work.
Last weekend i joined a club in the Netherlands that is working on and with metals incl "hard solder" they make steam engines.
Only difference i do is: i put wheels under the engine
Thanks for all the replays, got myself some food for my thoughts.
Best Igor.
