Hope I have not said anything out of place
You certainly said nothing out of place.
but he has built to quite close scale standards
Yes, on prototypical scale, fine scale, 1at32 and at NMRA1 standards
Payed attention for frog placement length and width of the sleepers and ties, safety rail ect.
I build some experiments, now it is time to move on and put them to the test.
The one scale that will win the "exam" will be the scale that will become my track.(strait and curve are quickly build and easy)
To drive on the trackwork i need to be very skilled in building cars and locos.
Cars/wagons they all drive perfect to my surprise.
However, the loco i bought had a 40mm between the wheels, and a 2mm thick flange incl transition cone to the wheel surface.
I could stretch them up (i think) to my desired 42mm between the wheels, then it would run on those turnouts and what not.
But the wheels are a bit to thick.
Another "mistake" i made with some turnouts is flange baring on the frogs.
Printing in ABS can be very good for a turnout, but not for a crossover or such, the track is creeping out.
Wood and putty.
To keep it cheap with the wheels (incl casting and a lathe) and have good driving it is almost mandatory to have gaps of 2.5mm up to 3mm.
Before i am going to buy/make or even run live steam, i would like my track to be good.
ABS is with live steam also out of the question, it can deform with the radiation heat from the fire box and kettle.
Again, a BIG thank you for all the forum users that give me a bit of help!
