beavercreek
whoops duplicate ahead!
Greg, thanks, yes I have - yep and it certainly helps as I have a couple of #6 points (turnouts) that I have converted to dead frog to help with continuity on other sections of the blades / rails.Rhino... did you add pickups to the tenders of your troublesome steamers? I find that makes a big difference, and also helps going over dead frogs..
Well, in my case the reasoning was simple - I wanted to have a battery loco that I could take to run when visiting lines that had dead rails, but also to retain the ability to run it on track powered DCC (or DC for that matter) at home, or visiting lines that had track power. While I removed the skates from both converted locos, I left all the wheel pickups in place, they are simply connected through the DPDT track/battery selector switch.
Sometimes I simply want to be able to drive the locos on my regular Massoth DCC control system rather than having to use a separate radio handset.
Greg, not really close to the sea -but about 10 miles. I have brass track, but I haven't weighted the tenders. That may do something for the 10-wheeler, but it may be risky on the Rogers as it's adhesion is on the light side even with added weight, and I do have some slight gradients where it tends to spin with three 1:20.3 bogie wagons in tow. I've got a couple of unintended humps which I intend to even out during the winter months, but that won't eradicate the gradients. If I clean the track at the beginning of the day, then the smaller locos will tend to stutter around dusk - I've always assumed this to be because of the dew.Interesting, I have no issues with wet rails, and once I have added tender pickups, no running issues at all, perhaps it is my stainless steel rails? I'm just curious because you emphasized very clean rail.
Do you get significant oxidation in a short time? Do you live near the ocean?
On second thought, even though most of my tenders are unsprung, I add weight to them, since most are supplied ungodly light and stringline easily.
Again, just curious.
My quest for an easier setup has led me towards Battery. Not near the sea but rails suffer after Rain, I always have to clean then to get decent running. I think it could be pollution from the main arterial Road near me (A1) and general heavy traffic around Town as well. If no rain I get a Month or two where running on DCC Power is just fine. Regarding Dew and Wet Track I find that DCC Sounds get a somewhat confused signal (the wrong sounds can occur on pressing an F key) and that is with with Malletts and big lumpy 2-10-2's.Interesting, I have no issues with wet rails, and once I have added tender pickups, no running issues at all, perhaps it is my stainless steel rails? I'm just curious because you emphasized very clean rail.
Yep, but we rather drifted onto my issue of iffy track - which then leans towards battery conversion.Holy Mackerel!!!
It was only a simple question not an excuse to start a flame war about which method is the best.
I was only curious about the reasoning.
From a personal point of view I went straight to battery from day dot (I do have 1 live steamer that; at this point in time is just a shelf queen).
I do not use any DCC type chips in my locos and I remove all electrical connections before conversion. (same config for all locos).
If DCC or DC or any other method floats your boat well all power to you.
As you point out, we've probably bored poor old Neil Holiday (who asked the original question) to tears.
But then people soon get used to thread drift here
Oh dear that is not what is meant by most of us, perhaps the caveat “mihi necesse est optimus” should be added to all posts about use of power for our Locomotives.Not to mention the "my way is the only way" when control questions are asked.
Oh google reckond that was the translation of ‘it my way not necesarily the best’!.? A Mini in the rain, is optimistic ?
I like the idea of ball bearing wheelsets in the tender, then I checked the prices; over here they're £36 for two axles (£72 for the tender according to my calculator) so battery conversion surprisingly looks a darn sight cheaperPerhaps ball bearing wheels with power pickups would be good on the tender, then the rolling resistance should stay low, but of course you will still be lifting more weight up the grade.
I wonder if it is dew, or just buildup on the rails...
Still thinking
But then you haven't got the spread of lots of little pickups along the length of the locoBecause of their cost, and the fact they are very effective.. You only tend to use one axle of these..
