Bit of RC servo help please
collectors
16 Apr 2022
277
11
67
Norfolk UK
www.chrismorris.co.uk
Hi, i wanted a cheap pan & tilt camera holder that was RC controlled & picked up a very cheap transmitter & receiver from good old China for £14 & it works fine with the exception that the joystick is very sensitive with no adjustments. I basically want to slow the movement down.
Would a pot on the signal wire work & if so what size. Or any other suggestion. Thanks.
3,553
The control pot is probably 10k. - Value might well be printed on it?
I think I would fit a 100 ohm pot at either end of the control. This would give you 'trim' for either end, the stick would then have a move limited range, giving you finer control.
I would not go more than 10% of the original pots value. - You may also find the stick only operates the existing pot over part of its range.
collectors
16 Apr 2022
277
11
67
Norfolk UK
Thanks Phil. What it was, the joystick has to be moved very gently & slowly. But with someone that gets the shakes at the best of times, its hard. I may also look at somthing to make the joystick longer.
GAP
14 Jun 2011
4,067
948
Australia
Open the transmitter up, find the joystick pot and bring it out to the front panel, then put a knob on it.
I did that with my throttles I get very fine control.
5,009
76
That sounds like a solution, I have Fosworks Tx and Rx units for my Roundhouse locomotives. The difference a control knob makes is a big help.
