Blanket weed or other weed stuff, can be very easy terminated, on two ways.
If you have no life in the pond, it will disappear as soon as they run out of food, no action needed.
Tap water contains some food for the weed, rain water less.
When the weed is dead it will rot and thus create 50% less food, ect. But autumn leaves will rot and thus create food.
So add more plant life, if plants are not surviving, there is to little food.
Use rain water instead of tap water as much as possible (it is also perfect for aquariums, better then tap water).
Rainwater is too soft for koi ponds, so add kh, gh and stabilize your ph that would be better than feeding your weed extra with tap water.
If you have life in the pond, you can escape blanket weed on two way's:
1: Chemicals, perfect short term solution, BUT don't forget that fish store there food in there tails during winter time/hibernation sleep.
Those chemicals will build up in those reserves, affect the immune system and here you go again to a fish doctor.
And you wont get rid off the food for weed:
A regular filter will only convert there urine and feces (ammonia and nitrite) to nitrate= algae food.
You will need a extra big plant filter or dilute a lot to get that level down to no food for weed.
Or you wont get rid of the food for the weed.
2: Salt, is very cheap and it will help the fish to get a thicker slime layer, more resistant to bacteria's parasites and viruses.
Before you add salt there is a rule of thumb and this is a very important one....NO MORE than 5 grams(metric!) per liter(fresh water pond's).
Add one gram a day (per liter of total volume) till the total amount is reached. yes 1000 liters will need 5 kilo, kilo at a day that is
Above 5 grams a litre water your filter bacteria will die or give them time to adjust slowly!(5-7 years) to a max of 7.5 grams a litre.
Check once in a while how high your concentration of salt is, especially after some raining weeks.
If you see whitish foam on your pond where the air bubble's are or during/after heavy rainfall you have eggwhite, this is the result of to much nitrate.
It is not harmful but means you feed your fish to much.
The food for weed is still there, but i can not survive in salt concentrations beyond 3 grams a liter.
Uvc lights or almagane lamps will help a bit, only to kill the floating cells, almagane will also kill young bacteria's and viruses(floating, so don't put it in your filter!).
Ozon machines will kill every cell.
Salt kill's all! except bacteria's
Salt can be bought very cheap, go to a store for live stock ask for feeding salt for cows, a bag of 25 kilo will cost you around 6.50 euro.
That stuff that they sell at pond stores for 5 times the price, is
exactly the same.....
After 40 years of experience with aquariums and 30 years with ponds(also build for others 40.000l+) i figured out a thing or two.....
All the stores will say this is bullshit and offer free medical exams and water testing(there test sets!) and will convince you to buy there salt and this and that ect.
Sinds i used regular salt in my ponds(15 years ago), no more weed, a big reduction in doctor bills and a very big reduction on my electra bill, yes i cut off 3 of 5 of my uvc lamps, each 125w 24/7 and 9 months a year.
My biggest pond was 20 meter plus, 8 meter wide and two meters deep....300.000 liter with out the pipes, systems or filters.
You want advice about a salt water pond? easy just ask, no problem
Ps, young pond's always have start up problems, it is only the first season, they must still stabilize due to tap water.
A fresh pond is still sterile, it must grow some bacteria's, don't buy those start up cultures, let nature do it her self, you will be better of.
Unwanted weed is not a temporary seasonal problem, it is a problem for the rest of your pond life.
Thanks for reading i hope this will clear up some, if not please ask
Best Igor
