korm kormsen
may i suppose, that "reasonably long" means more than four or five cars?
Hi All, my first post. I agree wholly with the above post. Even with short LGB cars we were having an issue...after watching the cars slowly, I identified the problem bit of track. Most of the curve is slightly superelevated by dint of the floating track and its response to our summer heat, and just the changing nature of ballast (in our case: crushed gravel). I simple put a bit of gravel under the outer rail on about a 6 inch section.A tip. When investigating derailment issues, ALWAYS check the track first before playing around with the rolling stock.
I've seen guys dismantle locomotives, make modifications, order spare parts in order to correct a derailment cause, when all along, it was a kink in a rail joint, or simple twist (uneven levels) on the track.
Regarding scale lengths...we are mostly interested in smaller European wagons and flatbed based cars. However, my son has a few longer cars with bogies (these did not navigate the curve, but do now after the repairs). They aren’t quite full scale length...perhaps 40 feet when scaled up. They look great. He is now after a small bullnose like an F3.
I do think longer cars look a bit off, especially the coaches (as pictured later in the thread). That said, to each his own and be merry!
Mike, how long is that coach? It's got to be probably 30 inches, no?
32.2" if its from PikoMike, how long is that coach? It's got to be probably 30 inches, no?
I have been trying to ID that coach with little luck. Length wise it streches over almost 3 R1 points as 300 mm each so that would pretty near match LGB Continetal SG Coaches at 800mm. Not found that design in LGB or Piko as yet so a bit of a mystery. But one thing is certain, you need to allow a large sized Kinetic Envelope with R1 Points and Curves BOTH sides.32.2" if its from Piko
Your memory serves you fairly well Jon - I only bought two! They're 817mm (32ins) long which is slightly longer than the LGB ones at 800mm. The livery is Alex (which I believe is part of Arriva's European operations). Piko also did a Taurus electric loco in matching livery. I Googled the full-size loco and coaches and the models are pretty accurate. As for the LGB DB coaches I've amassed five so far. Together they make a fine sight behind a red BR218 but the seven coach length is stretching it a bit - literally!It's definitely Piko, I remember Mike buying it (and a couple of others!) from Graham at Garden Railways Ltd at the Bressingham show a couple of years back.
