Oh, yes, Dave, it certainly helps! This is exactly the use I had in mind for the cable tray outside- even down to entering and leaving the garage (or shed, as you have shown). Furthermore, the lifting bridge arrangement with the pasting table hinges is what will be needed inside the garage to clear the access door, as I mentioned. The suspension bridge is inspired: furthermore, every bridge has the industrial 'feel' of the real thing.View attachment 250385View attachment 250385View attachment 250386View attachment 250387View attachment 250388View attachment 250389View attachment 250390View attachment 250391View attachment 250392View attachment 250393View attachment 250395
As you can see, I have used galv tray quite a bit on my railway, hopefully, the pictures are mainly self explanatory, most of the bridges were built at least 10 years ago , the green one nearly 20 years ago ( and in need of repainting!)
The big suspension bridge is made of Thermolite block, glued together, the suspension cables are 10mm earth wire , with 6 mm wire twisted in a battery drill to tighten it up , cable lugs at the bottom and 15mm copper pipe crimped onto the 10 mm wire. It does nothing to support the cable tray, it is only for show.
Hope this helps
Dave
Many thanks, Paul, GAP had spotted these people earlier on - I have a source of tray lengths closer to hand but not the accessories, on closer inspection, and so this is worth following up. Those 45 degree angles look interesting. Many thanks to both of you.I've been considering something similar to contain the ballast on my 'soon to be built' line. Both on suspended sections / bridge bases but also set into the top of embankments. All with weed control material to stop the ballast running through the holes. i was looking for some wide enough to carry twin tracks and found these people.
Direct channel do cable tray upto 600mm wide.
Medium Duty Premier Range
Available Sizes - 50mm, 75mm, 100mm, 150mm, 225mm, 300mm, 450mm & 600mm Widths x 3 Meter lengths
With a 25mm Return Flange
Pre-Galvanised.
See link below.
Regards,
Paul.
NB: They also carry zinc galvanising spray and brush on paint in a range of colours.
