Wow there is always an app these days. I do have the woodwork app that does each of the checks on their own, but this is a revaluation! Must must have the app.I've found a level checking solution inspired by Dunnyrail but using an old smartphone with a level checking app - mainly because it saved me a 20 mile drive to the nearest hardware shop and it actually found a use for the vile orange LGB hopper and an old phone. Note the pine packing pieces and cunningly crafted wedges. There are a few level apps available, I've tried three so far and they are all remarkably accurate - this of course depends on how good the phone sensors are (this is a venerable Sony).
I've run it around the worst affected area and discovered some nasty lateral variations which I have repacked and levelled. They didn't look that bad to the Mk1 eyeball but one of which, over the course of half a metre had a 5 degree change left to right on a rising gradient. Then the sun came out and I couldn't read the screen so that's it until the clouds return. Obviously a bit of a design flaw. Perhaps a cocktail umbrella? Only another 200ft to check...
Thank you everyone for the help, suggestions and pointing me in the right direction.
Strange you should mention this but I did see an app that used laser for levelling, probably wont be able to find it but I will have a lookGreat re-purposing..
Now.......... Is there an 'App' to use the torch LED, as a laser-level?
That's exactly what I meant Jon. I wouldn't dare use one on my line, it'd be too worryingHave shown this before but it is a very usable device, with a coupling a loco could trundle it round slowly - no getting down on your knees. Axle guards and wheels are by tenmille, but others may work or even on an LGB Flat Wagon.
View attachment 267134View attachment 267135
When I built my last Railcar I made the made one bogie so that it could twist forward and aft, the other port and starboard. This tends to account for many ills and I think that LGB Bogies and the 4 wheel vehicle ones may allow for this as well otherwise they would all flop to one side.
Woodwork app? I could havedone with one of those last week, it could have cut that bit of wood square for meWow there is always an app these days. I do have the woodwork app that does each of the checks on their own, but this is a revaluation! Must must have the app.
If only we could train them to clean tracks, lay down ballast (and make a cup of tea) - unfortunately when they get to the age when they are capable they just don't want to knowWelcome to the Forum!
Look's like your railway is 'softening' with the planting? - Long-ago, I also had a Daughter who was a 'climber!'.. First discovered when 'something' tugged at my trouser bottom's, when up the ladder.. Hannah, pink, fluffy romper-suit, and dummy in her mouth!- At that time, she could climb-up, but not back down
which made getting down the ladder 'interesting'!
If only we could train them to clean tracks, lay down ballast (and make a cup of tea) - unfortunately when they get to the age when they are capable they just don't want to know![]()
The engines canna take it Jim"warp" as we call it in the states, the equalization of our locos and rolling stock does not match the capabilities of the real thing,
