ebay mike
Couldn't find a specific section relating to 'overhead' matters and as I've got more than one question I thought I'd put them all in one place. Over the years I've accumulated quite a number of locos, trains and trams with pantographs, bow collectors or trolley poles. To date I've relied on the 'imagine it's there' principle in respect of the overhead wires. Not long ago there was a rather animated discussion in the coffee lounge about the lack of realism when running locos with pans down (or up with no corresponding infrastructure). This got me thinking as I have accumulated a significant stock of related items - enough to do a complete installation on my layout.
Here goes:
Just as a matter of interest I have several masts with bases. I recently bought some solar powered lights from Poundland which came with two part brackets I did not need for the installation I required. With a small amount of packing/adaptation they look as if they will fill the role at a pound a pop rather than the £5 plus for LGB ones. No promises or guarantees about suitability, but I'm off to the shops to stock up on a few before they all go. For the uninformed the genuine LGB item is the light grey one.
Here goes:
- Who runs stuff with the pantos up and actually in contact with the wires?
- Who relies on power via the overhead? I saw recently it can be problematic with DCC.
- Are there any associated problems with wear on either of the 'bits'?
- What about (in particular PIKO) stock that have current collectors made of plastic? Do you replace them with metal ones or adopt a method similar to Nodrog who uses fishing twine to limit vertical movement which would prevent actual contact?
- Who uses trolley poles (with wheels) on the LGB brass wires and are they troublesome?
- Some of my locos are DCC (Kroks, Taurus, LCEs etc.) but I have a number of analogue LCE sets and trams. Is it feasible to have analogue running at the same time as DCC using one rail as the feed and the overhead as return if the chipped engines are track powered only?
