Here goes:
No doubt there are other things I need answers to, but this will do for now.
- Who runs stuff with the pantos up and actually in contact with the wires?
- Who relies on power via the overhead? I saw recently it can be problematic with DCC.
- Are there any associated problems with wear on either of the 'bits'?
- What about (in particular PIKO) stock that have current collectors made of plastic? Do you replace them with metal ones or adopt a method similar to Nodrog who uses fishing twine to limit vertical movement which would prevent actual contact?
- Who uses trolley poles (with wheels) on the LGB brass wires and are they troublesome?
- Some of my locos are DCC (Kroks, Taurus, LCEs etc.) but I have a number of analogue LCE sets and trams. Is it feasible to have analogue running at the same time as DCC using one rail as the feed and the overhead as return if the chipped engines are track powered only?
When I check the DCC output on my 'scope, it shows an essentially square wave of +18v to -18v on my Lenz system with the PSU I use.I don't have the skills to draw diagrams on the computer in a reasonable time-frame, so this will have to be a thought-exercise..
These days, you tend to feed the output of a transformer (or a DC supply) into a 'controller' and the output of the 'controller'' is fed to the track.
'Controller' could be a DCC central station, or an analogue throttle, supplying a variable DC to the track.
Notionally, it would be possible to have a single transformer (could be a switched mode supply) feeding the inputs of both a DCC CS and an analogue controller. - This is the common source I am referring to. If there is a link here, it is possible (not definite) there could be a common path through the two controlling devices. As you say, this could cause some damage somewhere.
Now to the output voltages to the track/catenary:
The DCC signal/voltage is 24v peak-to-peak NOT +24v to -24v. This is a balanced signal, and you measure 'leg-to-leg' and not leg to ground.
The DC voltage will be (maximum) 24v. but again, unless 'we' make one leg 'grounded' it is just a potential between two wires. - It only by convention, we tend to call the negative/black wire 'ground'.
The black wire of the DC controller will only be at 0v. if we define the red wire as +24v. with respect to it. If you use the red wire as your reference, then the black wire is at -24v. with respect to that.
It is only when we either connect a wire to 'ground' / 'earth' / 'frame' or define that as a common-point it becomes 'ground'.
In our track and catenary scenario, we are using ONE rail for one leg of the DC only. - The other leg of the supply is the catenary.
The rail will float to some arbitary potential, but this doe not matter to the DCC system which is only looking between the two rails. The signal/DCC waveform will sit on top of this potential, but the decoder is looking at the difference between the two tracks with respect to each other, this will still be the 24v. DCC signal.
Having read that bacj, I have not explained it to well, but does it help?
In answer to No. 4So, going back to your first post:
1. It would appear some have/do do this.
2. Think we have covered this (in great detail! ) overhead analogue - YES, DCC- NO.
3. There will be some wear (obviously) but it should be reasonable.
4. No one has answered this specific point?? I would 'tether' the pants to avoid wear. - I would guess the rate of attrition would be pretty high??
5. Again, not addressed, but there have been threads on tramways and homemade wheels..
6. DCC on track only, and analogue via catenary, should be fine. - So your diagram should work.
Think that sums it up so far?
Geoff
Couldn't find a specific section relating to 'overhead' matters and as I've got more than one question I thought I'd put them all in one place. Over the years I've accumulated quite a number of locos, trains and trams with pantographs, bow collectors or trolley poles. To date I've relied on the 'imagine it's there' principle in respect of the overhead wires. Not long ago there was a rather animated discussion in the coffee lounge about the lack of realism when running locos with pans down (or up with no corresponding infrastructure). This got me thinking as I have accumulated a significant stock of related items - enough to do a complete installation on my layout.
Here goes:
Just as a matter of interest I have several masts with bases. I recently bought some solar powered lights from Poundland which came with two part brackets I did not need for the installation I required. With a small amount of packing/adaptation they look as if they will fill the role at a pound a pop rather than the £5 plus for LGB ones. No promises or guarantees about suitability, but I'm off to the shops to stock up on a few before they all go. For the uninformed the genuine LGB item is the light grey one.
View attachment 256264View attachment 256265View attachment 256266View attachment 256267View attachment 256268View attachment 256269View attachment 256270
Jim, I think Mel's wording is 'within the track centre needed for pantograph use' in order to provide for both panto/bow and trolley pole. The former have a very limited area above the rails in which they will function correctly, whereas the latter can swing quite dramatically outside the bounds of the roadbed.Nice write up and pics, however you mention keeping the wire in the centre, on the prototype the wire never remains in the centre but move from one side to the other, this provides even wear on the panto-graph, where and centre line catenary would quickly cause wear in the panto-graph.
Thanks, sorry I have been so lazy in updating the thread and rehosting old images, I really need to get onto that.Good to see more of your super line Mel. Much miss your talk in the Central as you have done some amazing stuff with Trams.
That's pretty much it Mike, for a pantograph the wire has to stay within the width of the conductor (just between the rails is usually a good rule for 45mm gauge) but a trolley pole is fairly tolerant of a wide range of lateral movement. This can be seen to full effect on trolley buses, which can pull over to the side of the road when the wires are centered above the traffic lane.Jim, I think Mel's wording is 'within the track centre needed for pantograph use' in order to provide for both panto/bow and trolley pole. The former have a very limited area above the rails in which they will function correctly, whereas the latter can swing quite dramatically outside the bounds of the roadbed.
Found this a really interesting thread. Catenary is something I've wanted to install for a while but have been put off by 4 things -
My biggest issue with building my own is I can't figure out how to suspend the wire such that the suspension "gubbins" don't foul the pantographs.. I like the way the LGB system uses a double wire with the suspension clips attaching to the top wire, leaving the lower one as a continuous smooth wire. However, I can't work out how to replicate this and whilst the pictures in this thread are very interesting, I can't work out how the various builders managed to achieve the same results with a single "wire" as LGB do with their double wire. If anyone could post close-ups of this or describe how they did it I would be very grateful!
- logistics of accessing the track to put locos and rolling stock on (I think I've figured out how to deal with this)
- physical access to all parts of my layout for maintenance (I am currently able to step over the track with relative ease but the increase in height by adding catenary will present me with a mobility challenge)
- cost of using LGB components (I thought the prices shown on various retailer websites for masts were for a box of 12, not for one mast!), and
- how to build my own system
I have a friend who has access to 3 different 3D printers so we're hoping to create some masts using one/all of them, and armed with the info and pics above hopefully we can create a workable system quite swiftly.
Hey David,LGB have produced 'overhead electric' models in 3 specific eras:-
Pre-Digital: each model was fitted with a switch to allow power collection from two rails, or from one rail and the catenary wire. The model had to be put on the track in a specific direction (determined by the traction tyre, or by a red dot on the motor block), and it was thereby possible to use two controllers at the same time, one to operate a wholly-track powered loco, the other to operate a 'catenary-and-one-rail' powered loco.
Direct Decoder: (by which I mean a loco supplied as analogue, but with an interface to which a decoder can be fitted) As an analogue loco, the instructions say "This model can be operated with track power or with power from an
LGB catenary system. There is a power control switch located inside the streetcar" (so no different from "pre-digital") but it goes on to say (twice!) "CAUTION! If this model is equipped with a Multi-Train System decoder, it must not be operated with catenary power. Operate decoder-equipped locos with track power only" but doesn't go on to explain why!
Factory-fitted Decoder: The instructions for trolley-pole fitted models (such as 21832) say "Hint: The catenary poles of this model are non-operational". The instructions for pantograph-fitted models (such as 23460) say "CAUTION! This model may be powered with a catenary on analog layouts only. For operation with the digital Multi-Train System, the model must use track power. Otherwise, dangerously high voltages may result".
I am a member of the group operating the catenary-fitted "Whiteleaf" exhibition layout, that is sometimes operated as a tramway (analogue control) or as an electric railway (digital control). The catenary is not powered for either format. The catenary is mainly LGB's standard masts but, for greater rigidity, we use Peco code 83 rail (in three-foot lengths) in place of LGB catenary wire. When inverted, the code 83 rail fits perfectly into the LGB wire holders. Each board (or pair of boards) has it's own section of catenary where the rail is soldered into the wire holders. The double grooves in the wire holders provide a secure, yet removable, connection between the separate sections. The sections of catenary fold flat for transportation (posts and wires in the same plane). We primarily use pantograph (or bow collector) fitted trams and locos and they are in contact with the "wire". With two springs fitted, LGB pantographs can apply too much pressure on the "wire" for reliable operation, so one spring is removed. Bachmann trams are either fitted with pantographs instead of trolley poles, or run with their trolley poles clipped down (or restrained with thread). A fuller description was provided in the article "An overhead success" in the Winter 2014 copy of the G Scale Journal (Vol 28 No. 4).
I'm not sure whether I have answered any of ebay mike's questions but hope I have provided some interesting "food for thought".
All the best
If a keep-alive (power-cap) module is added to the DCC decoder in your catenary/trolley-wire powered locos, you won't have any issues with DCC. The only issue with catenary vs track-power pickup is that a pantograph/trolley-pole only provides a single point of contact so is more prone to short power interruptions if the contact wire is not kept very clean. The keep-alive will allow the loco to keep running and hopefully find clean contact with the overhead.I saw recently it can be problematic with DCC
Would you be able to share a photo of the code 83 track being used as catenary wire on LGB MASTS.
