Rhinochugger
Retired Oik
These have been the bane of my life when installing battery conversions.
Life was fine when you could buy a chassis mounted socket with just two pins.
Now you only seem to be able to get ones with three pins, and it's never easy to work out which one you don't need -yeah and I know it's self switching but that's just too much for my tiny brain.
So I bought a pre-wired one - with two wires labelled for battery and two wires labelled for motor/controller (common live).
I have wired the simple installation (it's for lighting on my caboose) with a SPST switch for the lights operating through a cut out, and the battery socket is wired straight to the battery but using the same cut-out.
When I plug a charging plug into the socket, the cut out starts clicking - so there's a short.
My problem is where, why, how?
I've tested the socket as far as I can, and the two leads that I'm using are not shorting- it's only when the plug is inserted in the socket.
Any ideas
Any ideas
