Greg Elmassian
Guest
Well, you say "no fuse can limit this".... as stated that is not true... you could pick a fuse that would blow before the motor turned, and you could pick a fuse that would let the motor melt down in a bad situation (perhaps locking the rotor for extended times)
so that statement really makes no sense to me...
Otherwise I agree with your statements.
The insulation one is a little different... motors are wound with "magnet wire" which is a very thin coating, and SHOULD be pretty heat resistant... the Aristo motors were counterfeits and the insulating coating self destructed under heat... Aristo purchased replacement motors for all production and gave them to the unfortunate owners.
So it's really not the insulation thickness (which must be thin for efficiency) but the quality of application and heat resistance.
Regards, Greg
Regards, Greg
