Bits all returned from Fosworks. As well as fixing Steve had kindly taken the trouble to mark everything up so there can be no issues with me misconnecting things (Whisper it, I never noticed till he told me). Wired it all back up and tested it without the loco plugged in, everything fine and dandy. That is till I plug the loco in - bells and whistles start sounding randomly
![Bang Head :banghead: :banghead:](/styles/skype/smiley/emoticon-0179-headbang.gif)
I get over my fear of resetting functions on the Sierra card (it really is quite straightforward) but essentially nothing goes round the problem. Quick call to Steve at Fosworks and I arrange to take it up to the Peterborough show as he has kindly offered, without any pleading from me, to have a look and see what the problem might be. You'd think he had better things to do that day.
Solution found - seems like there is some interference from the motor causing the Sierra card to think it is getting "triggers" for its bell and whistle functions. Steve applies a "choke" to the cables from the motor and all is well. Phew !
Get home and next day go to switch it on for a run on my line - it's dead as a Do-Do. Would you believe it the a small wire from the rear light had become detached in transit and appears to have shorted across the output terminals of JohnS's PWM to Linear converter. Result - blown main fuse. Panic and cold sweat ensues
![Sweat :sweating: :sweating:](/styles/skype/smiley/emoticon-0107-sweating.gif)
Quick e-mail to Fosworks (on a Sunday) gets a swift reply
same day and the promise of 3 & 5 amp fuses. They arrive the next working day. Pop in a 3 amp, as advised by Steve, and all is well. The Fosworks "quick blow" fuse has done its job and protected all those valuable cards and hard work. Another phew
So now I've got some time off so I'll finish recommissioning the line for the new season and hopefully be able to sit back and relax to the sound of my K-27 chuffing around merrily. Hope the neighbours will be out
![Covered Laugh :giggle: :giggle:](/styles/skype/smiley/emoticon-0136-giggle.gif)
All around excellent customer service from Steve Foster at Fosworks - Big thank you. Max
P.S. I think I found the pickup connection from the drivers to the loco's electrical circuit. Checking the wiring for the head and classification lights, at the main terminal block under the firebox, I noticed an extra tag on one of the R/Hpair of terminal posts. Gave it a gentle tug and realised it was not connected to he lighting circuit nor the motor wires - QED it must be how the power is getting from the drivers to the rest of this loco. din't bin it but isolated the now detached tag with some shrink. So, the and tender & loco body should now all be isolated from any inputs from the track - famous last words.
