Greg Elmassian
Guest
Actually, on a budget, since she is running DCC, you can have the train enter the reversing loop, and while the train is still moving, flip the DPDT and the train will not even hiccup.
So I would not use a center off to keep the train moving, and a couple of LEDs at the 2 entrances to the reversing loop can indicate if that end of the loop is set for entry/exit. Put a red led on each side of the insulator on the same rail... if it lights then the polarity is not set right. Put a green led on one side of the insulator on rail A and the other lead on the other side of the insulator on rail B.
Green: ok to proceed, red, not ok...
simple and cheap.
simple and cheap.
