nicebutdim
I've just seen that b & q sell the composite board, about £8 a length (2 1/4 m length). Only problem is the colour, very dark grey, almost black.
Are they layed direct to the ground? Have you had any warping problems?Wobbleboxer said:I use gravel boards, similar size to decking boards but unfinished and therefore cheaper. No grooves, so I don't have the problem.
They're raised from a few inches to a foot or so (easier than contending with too uneven ground levels). Haven't had any warping problems in 3 years but I wish I'd covered them in roofing felt to add a few years to their life. They are fine at the moment but the weather will get them eventually. I'd still do it this way again.nicebutdim said:Are they layed direct to the ground? Have you had any warping problems?Wobbleboxer said:I use gravel boards, similar size to decking boards but unfinished and therefore cheaper. No grooves, so I don't have the problem.
Try here..................... http://www.trex.com/nicebutdim said:I think I may have opened pandora's box here, and here was me thinking it was a silly question... Where are the composite boards sold from, I'm quite tempted by that idea. Or another idea, I could go outside, crack a gas main, and when british gas turn up and then leave their plastic protective fence around the hole I have a free supply of some plastic boards. They may have red and white stripes on them but they'll last! If anyone here works for bg I'm only joking!
trammayo said:It is also true to say that if you cut the boards, the sawn ends should be treated as the tanalith doesn't penetrate right to the core of the timber. I was lucky to get a gallon of Ensele many years ago (dangerous stuff - contains arsenic) to seal the ends. I use a drop of washing up liquid to make the treatment "wet" so it will easily soak in. I suppose you could use this method with water based treatments.
Mick
yb281 said:When I built my deck the timber merchant supplied some special paint for sealing the ends.
trammayo said:Hi - can I add my sixpen'orth?
I used decking boards to construct some garden furniture. I made it flat side up and have no weathering problems (and we have a high humidity here).
It is fair to say that, as long as water doesn't lodge anywhere and the boards can dry, then they will last a long time. If you ballasted your track on the boards this would hold moisture. If you laid the boards groove side up, there would be less surface contact with the track so this would promote drying.
Mick
