Difference Roundhouse Argyll vs. Atlantic?
I suppose I should add that the biggest danger to their accuracy, is dropping them. Not impossible to put right, but troubesome and fiddly on small gauges.
Today I got a Summerlands Chuffer in the mail, that was rapidly installed.
It sounds not bad, but will improve outdoors with load I guess. Video:
youtu.be/fyXm8gvpXPY on Youtube.
Hi Rune
Thanks for the video which I found here:
http://www.youtube.com/watch?v=fyXm...of the chimney on this loco. Cheers Chris
The gas was perhaps a little high, as I was afraid it might go out. That's a thing I will have to learn over time.
I had to cut the pipes. Took a dremel and cut them 72 mm from the top of the chimney when the smokebox stood on the frame, where it should be.
Then I used a small file and rounded the edges of the pipes slihgtly, and took out the grades from inside the pipes. The chuffer was put in place with not much effort, and then I tapped it gently on top till it sat tight. I lifted the front of the engine from it, and it sat firmly. It was easy after watching you doing it in your videos. Thank you! The chuffer sits almost level with the chimney. I also gave it a bit of black paint on the top.
So now I wait for summer, tracklaying, and putting some load on the Argyll. Then I think the chuffer will sound just right!
But I noticed there was som steam from underneath the front of the engine. I suspect I must tighten some joints there. The nuts where the rods comes out from the cylinders were very loose, and I could turn them with my fingers. A bit of work with a spanner, and I think the joints will be fine.
The faulty pressure gauge will be changed for a working one. My dealer will see to that next weekend when I meet him on a MR-fair. He also mentioned something about changing the RC. So there we are then, a little bit of progress!
Have a nice day!
-Rune
Hi Rune
Well your fitting of the Chuffer sounds perfect - so it will sound great out on the track (not that I am biased or anything:)).
It looks cold where you tested it so there will always see alittle steam coming downwards from the chuffer. The leaking cylinder glands are not unusual, but just gently tighten them at first. If they still leak then undo them and wrap a little PTFE tape round the shaft and gently tighten them again. If too tight and they will stop it running.
The conversion to 2.4 ghz is well worth it but I can recommend the cheap stuff. I use RadioLink and I know the Planet and Saturn kit is good. I also know Roundhouse use RadioLink and Planet and they are a fraction of the price of Spektrum. In the UK they vary between £30 and £60.
Cheers
Chris
I have set up a testtrack, and steamed the Argyll for 40 minutes. Thats not bad I think! :)
Short video: youtube.com/watch?v=aIiY5AdghoQ
