So after a little thread drift via Benny Hill it was time for some work.
The Replacement gear arrived Oz a week ir two back and I finally got round to ordering some replacement Insulating Drivers from Roundhouse. All was set for a Rainy day that in part came on Sunday. Jack has been in bits now for a few weeks and the rebuild would incorporate the detail parts that I have obtained from Locoworks. The first image shows these parts which included a set of Footplates, Oil Castings, new Oil Tank Screw and Glazing Bars. The footplate already had the new Springs mounted on them by Locoworks.
The rebuild incorporated some attempts to reduce the likelyhood of a repeat of the burnout. So a fill in crossframe has been fabricated to sit just in front of the front set of drivers. This was screwed to the Frame Spacer and gets as close as possible to Track Level. Seen in the next two pictures.
Also seen in this picture is the Frame Top, well the unpainted bottom of it. This is an attempt to stop gas getting behind the Smokebox and into the Wheels and SloMo. You can see the vunerable Nylon Gear (white) in the pic below.
The Top of the cross flat can be seen painted Matt Black with the unpainted location where the original clunky Roundhouse Springs have been removed.
Gernrode Station.
All back together now and Jack has had a lot of touching up paint wise. I rather like the new Footplate, it certainly to me lifts the Locomotive somewhat. I have also weathered the Rods, though how long this will lastbremains to be seen. The Glazing shows up well as does the redundant new Oil Filler with its Red Brake look. This had to be replaced for the original as I forgot when ordering the bits that the Driver sits on the Oil Reservoir.
I have somehow missed the Smokebox Front Screw which should pull it down somewhat. Another little job that will probably involve a full strip down!
Silberhutte Station.
Out on the line with a Short Test Train. You can see the Driver sat on top of the Oil Reservoir, must get somewhat warm in the nether regions! Could not manage much better than this short Test Train as the Station in the Shed is still full of Track waiting to be sold !
A pic on the Viaduct was of course obligatory!
Running into Silberhutte Bunker First.
Alexisbad Station.
Examining the site of the burn up after taking Water. Note the burnt up Sleeper by the Brown Patch in front of the Loco.
Must do something about that horrible hole in the Sleeper, a leave over from when I used to use Brass Screws to hold down Track in my old Garden.
